benimaru
Replacement Super Hub plug
My plug for my super hub started buzzing then all the lights on my hub went blue, I turned it off and now it no longer comes on. I tried a neighbours plug and it worked so I just need a replacement 12v 1.5amp adaptor. Whats the easiest way to get a new one?
  • 10.82K
  • 308
  • 632
Re: Replacement Super Hub plug
Hi there benimaru,
Thanks for taking the time to post on the community.
I'm sorry to read you have a fault with the plug to the Super Hub.
If you can send me a Private Message confirming your name and address, I can arrange for a new power supply to be sent to you.
Speak soon
Sam
  • 10.82K
  • 308
  • 632
Hey,
Thanks for the reply and confirming your details, I appreciate it.
I've arrange for a new power supply to be sent to you which you will receive within the next few days.
If there are any further issues, by all means let us know.
Take care
Sam
