SuzieM42
Remote access to home WiFi
Hi - we have a Super Hub 2 and I was wondering if there is any way of switching off the WiFi when I'm not at home?  Would I have to set it up online beforehand via my account?  Or is there a mobile app I can use (I've looked on Google Playstore but there doesn't seem to be anything suitable).
Or am I not able to do it with this hub...?
Sorry, I've tried looking at the FAQ's etc on Virgin's site but can't find anything useful!
  • 9.36K
  • 799
  • 1.96K
Re: Remote access to home WiFi
You can set up remote access to the Hub's GUI and manually switch off the wireless radios.
Access the hub's GUI using http://192.168.100.1
Log in and click the Superhub Settings Icon.
There you can enable remote access to the hub using a port of your choice.
You will be able to access the hub from anywhere using the URL shown in the GUI.
