Marienewbold
Range
In need of a wifi expert. I have one room in the house that has such poor wifi!I am struggling to get a connection in it. Have tried a booster nearby but this doesn't work. It's either a poor quality one or I'm just doing something wrong. Anyone else had this problem. Is there someone on here that can recommend anything.
  • 2.96K
  • 378
  • 939
Re: Range
Wireless boosters are in IMHO snake oil as they rarely work and even when they do they reduce your speed by 50%.
A much better option is often powerline adapters.  These use the electrical wiring in your house to create a wired network without the need for long cables.  They are rarely as fast as the manufacturer's claim but are a lot more stable and less prone to interference than wireless.  Some provide just wired connections and others come with additional wireless built in to allow you to create a wireless access point in parts of the house where the wireless signal is poor.   Some powerline adapter reviews here:
http://www.pcadvisor.co.uk/test-centre/network-wifi/20-best-powerline-adapters-2016-uk-3490638/
Another option to improve your wireless is with a third party router.  It is what I and many other customers do and it can make a huge difference.
______________________
Scott
