  • 5
Nick_r_Thomas
Message 1 of 12
RCS and MDD Timeout.
Had a replacement Hub 3 due to old SH3 was failing to connect to network.
Now get RCS Failure and MDD Timeout.
Below is a copy of the log.
2016-12-27 17:35:49.0084000700RCS Partial Service;CM-MAC=**;CMTS-MAC=**;CM-QOS=1.1;CM-VER=3.0;
2016-12-27 17:35:58.0084020200Lost MDD Timeout;CM-MAC=**;CMTS-MAC=**;CM-QOS=1.1;CM-VER=3.0;
2016-12-27 17:36:02.0084000700RCS Partial Service;CM-MAC=**;CMTS-MAC=**;CM-QOS=1.1;CM-VER=3.0;
2016-12-27 17:36:14.0084020200Lost MDD Timeout;CM-MAC=**;CMTS-MAC=**
2016-12-27 17:36:14.0084000700RCS Partial Service;CM-MAC=**;CMTS-MAC=**;CM-QOS=1.1;CM-VER=3.0;
This seems to have been ongoing for about a month.  I will lose my cool if I have to speak to another 'advisor' from the call centre who walks me through the reset and reboot diagnostics sheet as it is only a short term fix.  If I can't get it sorted, I've been told by my wife to switch to Sky.
So it's Virgin's last chance.....
  • 347
  • 16
  • 69
wonkotsane
Fibre optic
Message 2 of 12
Re: RCS and MDD Timeout.
Probably going to need an engineer for this one but can you post your power levels in the meantime?
Massage an ego, click the kudos button. If someone answers your question, mark it as helpful.
Be nice, eat all your vegetables and keep your room tidy.
  • 5
Nick_r_Thomas
Message 3 of 12
Downstream
Channel               Frequency(Hz)           Power (dBmV)                SNR(dB)        Modulation                 Channel ID
1                                    290750000                         0.7                     33.3             256 qam                   16
2                                    322750000                         -0.9                    34.4             256 qam                   20
3                                    314750000                         -0.9                    35.5             256 qam                   19
4                                    306750000                         -0.5                    34.4             256 qam                   18
5                                    298750000                         0                         34.4             256 qam                   17
6                                    282750000                         1                         31.9             256 qam                   15
7                                    274750000                         -0.4                    30.3             256 qam                   14
8                                    266750000                         -2.7                    28.3             256 qam                   13
9                                    258750000                         -5                       28.7             256 qam                   12
10                                 250750000                         -3.9                    31.1             256 qam                   11
11                                 242750000                         -2                       29.4             256 qam                   10
12                                 234750000                         -1.2                    26.3             256 qam                   9
13                                 226750000                         -0.4                    25.4             256 qam                   8
14                                 218750000                         0.2                     25.9             256 qam                   7
15                                 210750000                         0.5                     26.3             256 qam                   6
16                                 202750000                         0.7                     26.4             256 qam                   5
17                                 194750000                         0.5                     26                256 qam                   4
18                                 186750000                         0.2                     26.1             256 qam                   3
19                                 178750000                         0.4                     27.8             256 qam                   2
20                                 170750000                         0                         25.8             256 qam                   1
Upstream
Channel ID Frequency(Hz)  Mode    Power (dBmV) Mod             Ch Bd(Hz)   Sym R (ksps)
2                       39400000                ATDMA          55                   16 qam             6400000                    5120
1                       46200000                ATDMA          55                   16 qam             6400000                    5120
  • 347
  • 16
  • 69
wonkotsane
Fibre optic
Message 4 of 12
Your downstream power levels are too low and your upstream power levels are right on the top end of acceptable. You need to all 150 and report it.
  • 9.01K
  • 760
  • 1.88K
Message 5 of 12
Downstream power levels are fine, it is the downstream SNR is too low.
With the high upstream as well, it might be worth checking the coax cable from the cable entry point to the hub for obvious signs of damage and all connectors are hand tight before phoning in.
You could always wait here about a week until a VM Forum Team member picks up the thread if you get no joy from First Line CS,
  • 347
  • 16
  • 69
wonkotsane
Fibre optic
Message 6 of 12
Sorry, you're right. I was trying to watch Cougar Town at the same time as reply to posts. Smiley Very Happy
  • 347
  • 16
  • 69
wonkotsane
Fibre optic
Message 7 of 12
And just to clarify: the Cougar Town marathon was my wife's idea, I'm just going along with it for the quality time together. That's my story and I'm sticking to it.
  • 5
Nick_r_Thomas
Message 8 of 12
Thanks for the info.
What is an acceptable SNR then?
  • 347
  • 16
  • 69
wonkotsane
Fibre optic
Message 9 of 12
For 256 qam they should be a minimum of 31.5dB according to the DOCSIS3 standard.
  • 5
Nick_r_Thomas
Message 10 of 12
Just spoke to 150 and was told that my problem is from over-subscription in my local area, so they are now load spreading until at least February next year!
I need the broadband to be reliable as I work from home and the local schools assume you have net access.
End Result........ After 20 Years of customer loyalty, Good Bye Virgin.
