Christain
Message 1 of 5
Problems with wifi
Currently having problems with wi-fi. I am using the super hub 2ac and currently can't connect to the internet via wireless on my computer. However my other devices can connect and use it just fine.
  • 16.13K
  • 1.34K
  • 3.27K
Message 2 of 5
Re: Problems with wifi
hiya @Christain with the computer what happens when you try, any error messages, also what version of windows/mac is running on it?
Christain
Message 3 of 5
Windows 7. I can connect to the router but I don't have any access to the internet. Other devices work fine on the same WiFi. There isn't any error message other than no connection.
  • 16.13K
  • 1.34K
  • 3.27K
Message 4 of 5
if you do a wired connection can you then get online?
Christain
Message 5 of 5
Ethernet has never showed up on my pc. Always used wireless. I don't even have the option to connect.
