  • 17
iryding
Message 1 of 9
Problems with ub 3.0 Connectivity
Can anyone shed some light as to what the problem with my broadband connection might be?
The current problem started last Wednesday, a faulty hub was diagnosed and a new one sent last Friday, however at that time the hub was fine. On Sunday last the connection failed again so the brand new hub was installed. VM Helpdesk are aware and an engineer is scheduled for this coming Sunday. The connection is fine for varying periods of time but then the hub goes off and the base light flashes green, the WiFi and double arrows flash green and occasionally red. After some 5 - 10 minutes the hub returns to normal operation with the Base light solid white.
This hub 3.0 is only two days old and the previous hub 3.0 was new in Nov 2016 after a hub 2.0 failure caused it to be replaced with a 3.0. When the hub is working I can get download speeds > 100mb/sec and upload >6.0Mb/secs.
Suffice to say I am pretty hacked off at the speed of response to problems (>6 days for an engineer) and the ongoing connectivity issues.
Here are the recent Network Logs: -
Date And Time Error Number Event Description
2017-02-20 09:11:12.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 09:18:09.00 67040400 DCC-ACK rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 09:18:42.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 13:08:23.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 20:09:33.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 20:09:47.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 20:09:48.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 20:10:04.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 20:16:28.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 20:16:29.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 20:25:04.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 20:25:16.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 20:30:48.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 20:30:49.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 20:34:13.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 20:34:13.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 20:56:40.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 20:56:40.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 21:22:27.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-20 21:22:29.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 16.5K
  • 1.38K
  • 3.37K
Message 2 of 9
Re: Problems with ub 3.0 Connectivity
Could you post the downstream and upstream
  • 17
iryding
Message 3 of 9
Re: Problems with Hub 3.0 Connectivity
Hi Paul,
Here are the upstream & downstream logs: -
Downstream
Channel Frequency(Hz) Power(dBmV) SNR(dB) Modulation Channel ID
1 563000000 -4.4 36.6 256 qam 20
2 555000000 -9.4 32.6 256 qam 19
3 547000000 -19.5 24.1 256 qam 18
4 539000000 -8 33.8 256 qam 17
5 531000000 -2.4 37.6 256 qam 16
6 523000000 0.7 38.9 256 qam 15
7 515000000 2.2 38.6 256 qam 14
8 507000000 3 38.9 256 qam 13
9 499000000 3.2 38.9 256 qam 12
10 491000000 3.7 38.9 256 qam 11
11 483000000 4 38.9 256 qam 10
12 475000000 4.6 40.3 256 qam 9
13 467000000 4.6 40.3 256 qam 8
14 459000000 4.8 40.3 256 qam 7
15 427000000 4.9 40.9 256 qam 3
16 419000000 4.6 40.3 256 qam 2
17 411000000 5 40.3 256 qam 1
18 443000000 4.8 40.3 256 qam 5
19 435000000 4.6 40.3 256 qam 4
20 451000000 4.5 40.3 256 qam 6
Upstream
Channel ID Frequency(Hz) Mode Power(dBmV) Modulation Channel Bandwidth(Hz) Symbol Rate (ksps)
2 39400000 ATDMA 44.3 32 qam 6400000 5120
4 25800000 ATDMA 44.3 32 qam 6400000 5120
3 32600000 ATDMA 44.3 32 qam 6400000 5120
1 46200000 ATDMA 44.3 64 qam 6400000 5120
Kind regards
Ian
  • 16.5K
  • 1.38K
  • 3.37K
Message 4 of 9
Channels 2 & 3 are of the scale, this will possible passed go networks so might take a bit longer to fix, depends what happens when engineer shows up
  • 17
iryding
Message 5 of 9
Hi Paul,
I'm not quite sure what you mean, however any tests done by the VM help desk have always pointed to the Hub. Will you advise the engineers to look at a particular part of the network?
Please clarify.
Many thanks
Ian
  • 16.5K
  • 1.38K
  • 3.37K
Message 6 of 9
The superuser group most of us don't work for virginmedia we help answer posts the best we can based on knowledge, as for signal levels your downstream and downstream signal to noise ratio (SnR) too low, am answering this on my phone you could read the sticky post at top snr premiere wrote by septh
I would be advising the engineer of low signal levels taking a record of these for references
  • 17
iryding
Message 7 of 9
Thanks Paul, would the low SnR levels indicate a problem within the VM cabinet outside my house or would they be on 'my side' of the installation?
Ian
  • 16.5K
  • 1.38K
  • 3.37K
Message 8 of 9
can be caused by both, but mainly cabinet/network end
  • 17
iryding
Message 9 of 9
Thanks Paul I will ensure the engineer checks the cabinet.
Many thanks
Ian
