  • 31
crrm
Problems since router reset yesterday (possible Area 22 error?)
We are experiencing dropouts since resetting our Superhub 2ac 24 hours ago... frequent resolving host errors, problems with smart devices, smartphones losing connection for a few seconds, etc. I'm using Google DNS and wireless set to 'best performance' but still seeing the problem. Had similar issue before (2 years ago) and had the hub swapped out. We now have unrelated wifi issues with this hub, but nothing as bad as today.
Downstream Channels Lock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked 1 202750000 Hz 256 QAM 2.5 dBmV  38.6 dB 284 280
Locked 2 210750000 Hz 256 QAM 2.5 dBmV  39.0 dB 1054 1019
Locked 3 218750000 Hz 256 QAM 2.4 dBmV  38.3 dB 278 278
Locked 4 226750000 Hz 256 QAM 2.4 dBmV  38.3 dB 289 289
Locked 5 234750000 Hz 256 QAM 2.3 dBmV  39.4 dB 301 300
Locked 6 242750000 Hz 256 QAM 2.1 dBmV  39.4 dB 307 307
Locked 7 250750000 Hz 256 QAM 1.9 dBmV  39.0 dB 915 915
Locked 8 258750000 Hz 256 QAM 1.8 dBmV  38.6 dB 956 956
Just to confuse matters, we also seem to be seeing the same Leeds/ Area 22 outage as mentioned here. I'm wondering if that's what's causing it?
30/11/2016 10:22:49 GMT 84000510 Downstream Locked Successfully
30/11/2016 10:22:36 GMT 68010100 DHCP RENEW sent - No response for IPv4
30/11/2016 10:22:15 GMT 68010100 DHCP RENEW sent - No response for IPv4
30/11/2016 10:21:34 GMT 68010100 DHCP RENEW sent - No response for IPv4
30/11/2016 10:20:10 GMT 68010100 DHCP RENEW sent - No response for IPv4
30/11/2016 10:17:21 GMT 68010100 DHCP RENEW sent - No response for IPv4
30/11/2016 10:11:43 GMT 68010100 DHCP RENEW sent - No response for IPv4
30/11/2016 09:31:05 GMT 68010302 DHCP WAN IP - *******
30/11/2016 09:30:31 GMT 68000407 TOD established
30/11/2016 09:30:15 GMT 82000200 No Ranging Response received - T3 time-out
30/11/2016 09:30:07 GMT 82000200 No Ranging Response received - T3 time-out
30/11/2016 09:30:06 GMT 82000200 No Ranging Response received - T3 time-out
30/11/2016 09:29:56 GMT 84000510 Downstream Locked Successfully
 [MOD EDIT: For your security personal and private information has been removed from this post. Please review the Forum Guidelines]
  • 31
crrm
Re: Problems since router reset yesterday (possible Area 22 error?)
Just had another drop out at 11.16am. The only clue I can see is that the DHCP lease time seems to run out/ renew around that time.
There's nothing in the logs to suggest a problem around 11.16, weirdly.
I will set up a quality monitor and see if I'm getting the same outages as everyone else...
  • 31
crrm
My Broadband Ping - Virgin
Looks like I am getting the same outages every 50-60 min as the other users in Leeds.
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Hi crrm,
Thanks for letting us know about your connection dropping out, I apologise for any inconvenience caused.
I have tested your connection from here and I can see that there's a number of T3 time outs inside the Hubs logs which will explain the disconnections you mentioned.
I would need to arrange for an engineer to attend and investigate things further for you, I will send you a PM (purple envelope at the top) detailing what's required in order to proceed with making the booking. Please respond to me there and I'l get this sorted for you.
Take care,
Adam.
