Fletchd
Problem with modem dropping internet access
This is happening frequently now, especially if the modem is powered of.
29/12/2016
 04:40:04
 2436694078
 TOD established
 27/12/2016
 05:01:48
 82000500
 Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
 27/12/2016
 04:45:56
 82000600
 Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
 27/12/2016
 04:45:56
 82000800
 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
 27/12/2016
 04:21:57
 2436694061
 Dynamic Range Window violation
 27/12/2016
 04:21:18
 84020300
 MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
 27/12/2016
 04:19:07
 82000800
 16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0
Downstream Channels
Lock Status
Channel ID
Frequency
Modulation
Rx Power
SNR
Pre RS Errors
Post RS Errors
Locked
17
299000000 Hz
QAM256
5.3 dBmV
37.9 dB
543258
26090
Locked
13
267000000 Hz
QAM256
3.9 dBmV
37.7 dB
701311
25533
Locked
14
275000000 Hz
QAM256
4.0 dBmV
37.8 dB
591947
21610
Locked
15
283000000 Hz
QAM256
3.8 dBmV
37.8 dB
560177
22691
Locked
16
291000000 Hz
QAM256
3.4 dBmV
37.9 dB
555857
25813
Locked
18
307000000 Hz
QAM256
5.1 dBmV
38.1 dB
551001
24258
Locked
19
315000000 Hz
QAM256
5.1 dBmV
38.2 dB
576110
17733
Locked
20
323000000 Hz
QAM256
4.8 dBmV
37.9 dB
658222
12459
Upstream Channels
Lock Status
Channel ID
Frequency
Modulation
Tx Power
Mode
Channel Bandwidth
Symbol Rate
Locked
6
39400000 Hz
ATDMA
41.3 dBmV
16QAM
6400000
20480 Kbits/sec
Locked
5
46200000 Hz
ATDMA
40.5 dBmV
16QAM
6400000
20480 Kbits/sec
Unlocked
0
0 Hz
Unknown
0.0 dBmV
Unknown
Unknown
0 Kbits/sec
Unlocked
0
0 Hz
Unknown
0.0 dBmV
Unknown
Unknown
0 Kbits/sec
Been doing this for months now, after a reeboot it comes back on after 10 mins or so.
I have done a full reset a few times , runs ok for a while but fails again.
Help!
  • 3.88K
  • 121
  • 203
Forum Team (Retired) Adam_L
Re: Problem with modem dropping internet access
Hi fletchd,
Thanks for the post! I am sorry to hear about your modem dropping internet access, I apologise for any troubles caused.
I have tested your connection from here, and I can see a large number of T3 and T4 time outs inside the Hubs logs.
An engineer will need to attend in order to resolve this for you. I will send you a PM (purple envelope at the top) detailing what's required in order to proceed with making the booking.
Please respond to me there and I'll get this all sorted for you.
Take care,
Adam.
