Mez_million
Power levels and time out
Hi can anyone please check my power levels seem to be timing out quite a bit ? Thanks
First Time Last Time Priority Error Number Description
19/12/2016 21:52:32 GMT 19/12/2016 21:52:32 GMT Warning (5) 66050310 Auth Success - Web login successful.
19/12/2016 21:19:01 GMT 19/12/2016 21:19:01 GMT Warning (5) 66050310 Auth Success - Web login successful.
19/12/2016 21:03:29 GMT 19/12/2016 21:03:29 GMT Warning (5) 66050310 Auth Success - Web login successful.
19/12/2016 21:00:14 GMT 19/12/2016 21:00:14 GMT Error (4) 68010302 DHCP WAN IP - **********
19/12/2016 20:59:14 GMT 19/12/2016 20:59:14 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
19/12/2016 19:53:18 GMT 19/12/2016 19:53:18 GMT Warning (5) 66050310 Auth Success - Web login successful.
19/12/2016 19:16:09 GMT 19/12/2016 19:16:09 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
19/12/2016 19:16:07 GMT 19/12/2016 19:16:07 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
19/12/2016 19:16:06 GMT 19/12/2016 19:16:06 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
19/12/2016 19:16:05 GMT 19/12/2016 19:16:05 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
19/12/2016 19:16:04 GMT 19/12/2016 19:16:04 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
19/12/2016 19:16:02 GMT 19/12/2016 19:16:02 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
19/12/2016 19:16:01 GMT 19/12/2016 19:16:01 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
19/12/2016 19:16:00 GMT 19/12/2016 19:16:00 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
19/12/2016 19:15:59 GMT 19/12/2016 19:15:59 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
19/12/2016 19:15:57 GMT 19/12/2016 19:15:57 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
19/12/2016 19:15:56 GMT 19/12/2016 19:15:56 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
Downstream
DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 507000000 515000000 523000000 531000000 539000000 547000000 555000000 563000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 13 14 15 16 17 18 19 20
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17
Power Level (dBmV) -2.93 -0.84 -1.95 -0.79 -2.44 -1.98 -3.20 -3.80
RxMER (dB) 34.48 34.93 34.63 34.63 34.77 34.77 34.77 34.63
Pre RS Errors 7097 3243 3348 5267 2465 2651 1890 2998
Post RS Errors 1006 933 936 987
Upstream
US-1 US-2 US-3 US-4
Channel Type 2.0 N/A N/A 2.0
Channel ID 10 N/A N/A 12
Frequency (Hz) 39400000 N/A N/A 25800000
Ranging Status Success Other Other Success
Modulation 64QAM N/A N/A 64QAM
Symbol Rate (Sym/sec) 5120000 N/A N/A 5120000
Mini-Slot Size 4 N/A N/A 4
Power Level (dBmV) 50.50 N/A N/A 49.00
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 0 0 0 0
T4 Timeouts 0 0 0 0
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Re: Power levels and time out
Hi Mez_million,
Thanks for the post! I am sorry to hear about your issues with your broadband timing out, I apologise for any inconvenience caused.
I have tested the connection from here and I can see a number of T3 time outs inside the Hubs logs, an engineer will be requirwed to attend and investigate this further for you.
I will send you a PM (purple envelope at the top) detailing what's required to proceed with making the booking. Please respond to me there and I'll get this all sorted for you.
Take care,
Adam.
