  • 69
  • 5
ibbotson
Port forwarding Hub 3
Have just set up Hub 3 and all seems OK, except for my CCTV System. I had to set up port forwarding on previous Hub 2, but how do you do port forwarding on the Hub 3
  • 38
  • 5
SirThomas
Re: Port forwarding Hub 3
See the attached...
Quite easy to do, but the seemingly endless wait for the GUI to load and the buggy DHCP assignment is a pain.
Make sure that you've got the correct IP/MAC association, as this confused me immensely at first!
Tom
Note: MAC address does not matchNote: MAC address does not matchPorts.png
  • 69
  • 5
ibbotson
Hi, Many thanks for responding. I did manage to locate the port forwarding section  after logging in via the hubs IP Address, and yes it was easy to do.
