  • 10
Unhappy_Hammer
Message 1 of 13
Port Forwarding rules now not working
I've set up several port forwarding rules some weeks ago so that I can view some remote CCTV cameras. However, it now seems (last Friday) that the ports are no longer responding.
Any ideas? I have the V2 Superhub.
Cheers.
  • 16.12K
  • 1.34K
  • 3.27K
Message 2 of 13
Re: Port Forwarding rules now not working
hiya @Unhappy_Hammer if you remove the rules/reset the router and re-add does it work ok?, also does it work on a local connection when accessing from your home PC/laptop?..
  • 10
Unhappy_Hammer
Message 3 of 13
Hi @paultechy I have deleted them twice now and the routers been on and off several times now
  • 11
connor_p
Message 4 of 13
Have you tried disabling the firewall?
Failing that, it might be worth pin-hole resetting your SH.
  • 10
Unhappy_Hammer
Message 5 of 13
I'm testing the ports on my PC server which is locally connected.
  • 10
Unhappy_Hammer
Message 6 of 13
Yep, tried disabling the firewall.
Also, I've pulled the power on the SH several times, is this the same a pin hole reset?
  • 11
connor_p
Message 7 of 13
A pin-hole reset would reset your SH to the factory default settings. You'd have to customise it again (if you did before, that is).
  • 11
connor_p
Message 8 of 13
Are you able to ping the port by any chance? From the PC, run Command Prompt, and type 'ping [theipaddress:0000]'. Replace 0000 with the port you've set the rule up for.
  • 10
Unhappy_Hammer
Message 9 of 13
Thanks connor_p it's coming back "ping request could not find host"
  • 11
connor_p
Message 10 of 13
OK, give pin-hole resetting the SH a go. Make sure you hold the pin in for around 5-10 seconds. Let us know how it goes.
Feel free to drop me  a PM if you need assistance.
