peter88uk
Port Forwarding Issue on Hub 3
Hello,
I've recently been given a new Hub 3 from Virgin after upgrading my package. I've got a few ports that I need to forward, so I've gone on and set these up and they work, but only for like an hour probably less - to get them to work again I have to disable and enable the two rules again. Has anyone else had this issue?
It's very frustrating!
Thanks.
  • 16.46K
  • 1.37K
  • 3.36K
Re: Port Forwarding Issue on Hub 3
hiya @peter88uk welcome to the virginmedia community forum, your're not alone on this.. the port forwarding is a bit buggy, best idea to resolve all these issues is to put the hub into modem mode and use a 3rd party router, since no planned date for having these bugs fixed. if you've not on the 300mb tier you could switch back the previous hub if you where using a superhub 2.
if you're looking for suggestions for a 3rd party router, a few of my fellow superusers and community users advise something like the asus rt68u series, not cheap but well worth it.
peter88uk
Thanks Paul,
Unfortunately I was upgraded from the original superhub so I don't have a superhub 2. Hard to believe there isn't a planned date for the fixes to be honest especially if there are so many people reporting issues!
I'll have to make a decision on if I was to shell out for a router, thanks for the advice.
