emmabell42
Just joined
Poor connection with SuperHub 3.0
Hello,
We upgraded to the SuperHub 3.0 router last week. In that time, our connection has been variable. It cuts out several times a day and runs slowly. Does anyone have any advice please?
Emma
Here are my diagnostic results:
Diagnostic Results...
WiFi signal strength of FionaZen-PC is -71dBm.
WiFi signal strength of android-64cfa4a083afdc53 is -57dBm.
WiFi signal strength of Chromecast-Audio is -65dBm.
WiFi signal strength of android-6d825ea6daa56824 is -58dBm.
WiFi signal strength of android-924ce82f30a93985 is -50dBm.
Wireless primary network is Enabled on 2.4GHz.
Wireless primary network is Enabled on 5GHz.
Telephone line 1 is disabled
Telephone line 2 is disabled
Wired client on port 4 is running at 100 Mbps.
Wireless guest network is Disabled on 2.4GHz.
Wireless guest network is Disabled on 5GHz.
  • 10.72K
  • 314
  • 658
Re: Poor connection with SuperHub 3.0
Hey there emmabell42,
Thanks for posting and a big welcome to the community Smiley Very Happy
Sorry to hear about your connection problems. Can I ask if you're using a wireless or hard-wired connection when you notice the disconnections? If you're using the wireless, I would recommend changing your wireless channel as this will often improve problems caused by wireless interference.
Hope this helps,
Take care.
Heather_J
