  • 8
VK50
Message 1 of 9
Ping responses on Hub 3.0
I've just been switched to a Hub 3.0.  Testing the firewall at https://www.grc.com/ indicates a failure because of responding to ping (ICMP echo) requests.  How does one turn off the response to ping requests in this version of router?  It was possible in superhub 2.
  • 514
  • 27
  • 121
deviousiphone
Rising star
Message 2 of 9
Re: Ping responses on Hub 3.0
Enable the firewall on the router should do this.
  • 8
VK50
Message 3 of 9
Firewall is enabled, and it doesn't!
  • 10.82K
  • 308
  • 632
Message 4 of 9
Hi VK50,
Thanks for taking the time to post on the community.
I'm sorry to read that you are having issues with testing the firewall due to ICMP requests.
Normally to turn off the ping requests on the Hub 3 you would need to enable the firewall within the router, however as you have mentioned, this has not worked.
As I am not familiar with the site that you are using are you able to post a screen shot of the error message that you receive when trying this. If it has sensitive information on it, by all means send it in a PM (purple envelope icon, right corner).
To make sure that the ICMP ping requests work you can try to create a Broadband Quality Monitor, with both the firewall disabled and enabled. If you do set up a BQM, with the ICMP disabled you will see a red block of data on the graph.
Hope to hear from you soon
Sam
  • 362
  • 16
  • 83
pyrotenax
Fibre optic
Message 5 of 9
Why do you feel the need you want to block it ? Have a read on here ... http://security.stackexchange.com/questions/22711/is-it-a-bad-idea-for-a-firewall-to-block-icmp
Running ASUS RT-AC88U with Asuswrt-Merlin firmware
  • 8
VK50
Message 6 of 9
Thanks very much for all that information!  I'm not by any means a security expert but have used the grc shields up web site for many years and have always blocked the ping responses, including with my previous Virgin hub, with no observable bad effects.  When I recieved a "failed" message (see my response to the previous note in this series) I thought I ought to at least ask some questions.  From your response I'm worrying unduly.
thanks again.
  • 10.02K
  • 332
  • 876
Hero
Message 7 of 9
Maybe they changed it so that Ping responses is blocked when the firewall is off
  • 10.94K
  • 238
  • 2.01K
Message 8 of 9
Counter intuitive but I disabled FW on 9.1.116V for last 15minutes and TBB (AND "f8lure") still recording ICMP echo's. Of course a more comprehensive test would include both a reboot and FR over a longer period.
Regards Tony
"Life is a Binary Inspired Turing Computed Hologram"(don't PM or @Mention me - in case ignoring you offends)
  • 10.02K
  • 332
  • 876
Hero
Message 9 of 9
so they changed it so that the Ping response is allowed with FW on/off.
