  • 5
cfm200
Message 1 of 5
Password to admin control panel incorrect
I'm trying to access the admin controll settings panel and the password is clearly shown on the bottom of my router but when I try to type the admin panel password in it says the password is incorrect? I have also pressed forgot password and typed my email address in to reset the password but no email has been sent to me
  • 3.01K
  • 383
  • 952
Message 2 of 5
Re: Password to admin control panel incorrect
You could try a pinhole factory reset that should reset all passwords back to the defaults, but it will also wipe any wireless config changes that may have made in the past.
______________________
Scott
  • 2.76K
  • 223
  • 842
Dave_cq
Trouble shooter
Message 3 of 5
I can't speak for the latest Hub 3 but the earlier hubs had a default access of admin with a password of changeme
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
  • 285
  • 10
  • 49
BrianY
Superfast
Message 4 of 5
Looking on the underside of the SH3, look for WiFi password box.
Below this in a smaller box is an all number 8 digit code, this 8 digit code is the one to enter!
[Unable to locate the recent post that highlighted the actual location]
dannyg
Just joined
Message 5 of 5
wheres admin on here lol
