hipsway
Password not allowing access to settings Hub 3
Hello,
I have a super hub 3.0 and I'm trying to access the settings page.
I can browse to 192.168.0.1 ok, and I get the password prompt. But I cannot seem to login. I have tried the password printed on the bottom of the router, and I have even done a hardware reset, but I still get "the password you have entered is incorrect".
I have pressed the reset button on the back for 30 seconds and then switched router off all to no avail.
Any suggestions as to how to get access to settings?
hipsway
Re: Password not allowing access to settings Hub 3
There's a settings password on the bottom of the router, different from the wifi password, I did not notice this :-(
That worked, I'm in the settings now.
