  • 23
NathanT22
Message 1 of 8
Packet loss/ Latency / Ping Issues
Hello,
I'm getting packet loss in the day and in the evening. I've done a thinkbroadband monitor and its showing up as I'm loosing packets, I was wondering if somebould could tell me when this will be fixed in my area.
Thankyou Smiley Happy
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Message 2 of 8
Re: Packet loss/ Latency / Ping Issues
Hi NathanT22,
Thanks for letting us know that you're having ping spikes throughout the day and  in the evenings also, I apologise for any inconvenience.
I have tested things from this side and I couldn't see anything out of the ordinary, no errors or time outs inside the Hubs logs and all of your power levels are within the preferred ranges.
I also checked your area cable for any issues and that also tested great, showing no errors and all the signal levels are correct.
Are you still having these issues? If so, could you please respond to me here with a Trace Route within command prompt for me to have a look at.
Also, how are you connected wired or wireless?
Take care,
Adam.
  • 23
NathanT22
Message 3 of 8
Hey, there is an issue because I contacted virgin media on the phone the other day and spoke to the line 2 broadband team. the advisor couldn't find anything wrong until he went into my downstream and upstream. and he Said there is a problem as I can see in the evening your getting bad issues. but he couldn't do anything because he said something about its classed as a minor issue because nobody else has complained about it in my area as much. so there is a problem and it needs to get sorted out asap, I'm on a wired connection, I even did a wired speed test when I rang the advisor team and I was getting 16MB download speed.
  • 23
NathanT22
Message 4 of 8
www.thinkbroadband.com/ping/share/32b1dfa19d243d0b0b80a0dfe729f1c0-08-11-2016.html
  • 23
NathanT22
Message 5 of 8
This is my downstream. when the advisor checked it the other day it was very bad in the evening, he said i was getting 90% or something which was bad.
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)267000000275000000283000000291000000299000000307000000315000000323000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID123124125126127128129130
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)1.721.731.591.791.881.731.511.74
RxMER (dB)37.0937.3637.3637.0938.2637.9437.6437.94
Pre RS Errors15641066422387287310974305
Post RS Errors298285284302281302972302
  • 23
NathanT22
Message 6 of 8
This is my upstream.
Upstream   US-1 US-2 US-3 US-4
Channel TypeN/A2.02.0N/A
Channel IDN/A41N/A
Frequency (Hz)N/A2580000046200000N/A
Ranging StatusOtherSuccessSuccessOther
ModulationN/A16QAM16QAMN/A
Symbol Rate (Sym/sec)N/A51200005120000N/A
Mini-Slot SizeN/A44N/A
Power Level (dBmV)N/A47.7549.25N/A
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
  • 3.88K
  • 120
  • 203
Message 7 of 8
Hi NathanT22,
Thanks for responding to me! I appreciate you providing the information I requested, this has been a big help to diagnostics.
I have had another look over the connection and all is still clear, no errors or time outs and your area cable looks great as well.
It may be a good idea for you to set up a Think Broadband monitoring graph and post back here in a couple of days with a copy for us to look at.
Take care,
Adam.
  • 23
NathanT22
Message 8 of 8
I've done a monitor of it, I sent it in the first URL link I sent you. I don't know how to send you the grapth on here so I couldn't send it on here.
