wilfsta
PS4 constantly drops connection
My PS4 has wired connection and constantly drops connection. This could be gaming or listening to Spotify. It has only just started happening in the last week.
When it drops the tick starts flashing and the arrow lights below flash green.
  • 3.01K
  • 383
  • 952
Re: PS4 constantly drops connection
If you go to http://192.168.0.1/ (or http://192.168.100.1/ if you are in modem mode) to get the VM hub GUI. Don't login but instead click on Router Status which is either a button in the top right of the screen or a text link at the bottom of the screen depending on which hub you have. Click on the Downstream, Upstream and Network Log sections and copy & paste the figures from those screens and post them here, don't worry about the formatting or you can post screenshots if that is easier. Be careful to edit out or obscure any reference to your WAN IP or MAC address in the log to protect your privacy.
The community can have a look for you and see if anything in the figures looks wrong and advise accordingly. Or you can wait for the VM staff to pick up this thread (can take up 7-10 days) and run checks on your line.
______________________
Scott
