  • 5
darkblue1965
Nordvpn router connected to VM hub 3.0
Hi I am trying to connect a Linksys wireless router running shibby Tomato firmware 1.28 to my Virgin hub 3.0.  The router will be used as a VPN with Nordvpn account installed on it.
I have tried followng instructions from this site for doing this using VM hub 2.0 but screenshots I have seen seem to differ to what I see when I go into the settings for VM hub 3.0.
So far I have changed VM hub 3.0 to operate in Modem mode. Connected an ether net cable from a LAN port to the WAN port on the Tomato router. I have then restarted the VM hub and then Tomato router.
When I scan for wireless the VM wireless has gone and I see the Tomato router.
I connect to the Tomato wireless successfully but there is no actual Internet access.
I assume I must change the internal settingstorage of the VM router? Any help appreciated, thanks.
BrianAscroft
Settling in
Re: Nordvpn router connected to VM hub 3.0
Hi @darkblue1965,
What model of Linksys router are you using? Is it a Cisco device?
  • 5
darkblue1965
The router I am using is a LINKSYS wireless WRT54GL Flashed with Shibby Tomato 1.28.
