macc70
Just joined
No wifi Connection with ethernet connected only
We lost wifi when a cable was broken by workmen close by   Since this happened I have had connection with Ethernet only No wifi  Believe a large area was covered by the loss of connection
thanks for any help solution
  • 22.4K
  • 863
  • 3.26K
Re: No wifi Connection with ethernet connected only
broken connection to your coax would effect wireless and wired. if you have wired connection then the fault is not the network. It may be your devices or the superhub/router.
Have you tested wireless on more then one device? if non have a signal make sure the wireless has not been disabled on the SH
  • 502
  • 63
  • 142
backtothefuture
Fibre optic
As apcyberax says a broken cable would affect your internet as a whole, not purely your Wi-Fi unless your device or router is faulty and/or the Wi-Fi disabled.
If I have helped please feel free to give 'Kudos' by clicking on the thumbs up icon against any of my posts. If I have helped to solve an issue you can also click on the 'Mark As Helpful Answer' link to mark it as helpful.
  • 11.02K
  • 324
  • 670
Hey macc70,
Thanks for joining the community Smiley Very Happy
Sorry to hear about the problems with your wireless connection.
Am I right in thinking this is an external cable issue that is affecting your local area? Please correct me if I'm wrong.
What is the latest with this? Have you had any updates or would you like me to investigate further.
Catch you again soon,
Take care.
Heather_J
