Jamesyt
No ethernet signal but have wifi
Hi there unsure about this since got hub 3 ethernets been working fine hardwired laptop and powerlines for my 2 sons ps4s today nothing did loopback that gave me solid green light lan 1 and 3 am sure i used also reset router which worked for 5 minutes then nothing enginner arranged for wed 16 th aug any other suggestions requested new hub or back to my hub 2 which had no problems any help wouod be gratefull
Jamesyt
Re: No ethernet signal but have wifi
Am new to all this technical jargon but rebooted router still same problem done loopback with ethernet got 2 green lights but still no connection swopped cable for another cat 5 viola seem to have worked have connection again will keep eye on it then if persists will attempt what you said thanks for reply appreciated
  • 10.98K
  • 323
  • 669
Hey Jamesyt,
Thanks for getting in touch, welcome to the Community Smiley Very Happy
I just wanted to pop by and see how you're getting on since your last post? Apologies for the recent problems you've experienced, if you need my help with anything, please just ask.
Take care.
Heather_J
