  • 82
alyboy
Message 1 of 11
No connection
Our internet has been down since about 11am this morning. any info on this please? rebooted modem multiple times. when i check the hub settings it says registration failure. cheers
  • 251
  • 19
  • 63
zvonok
Superfast
Message 2 of 11
Re: No connection
Quickest way is got VM website and check status for your postcode area - (using a mobile) then if poss log-in and select option to check your kit out - then enter the results here if need be ... ZVNK ...
  • 82
alyboy
Message 3 of 11
Re: No connection
yeah i checked before, it's all good, no known issues right now
  • 82
alyboy
Message 4 of 11
Re: No connection
just want to update this post, it's still down. Had no internet since 11am. really need this sorted by tomorrow.
  • 82
alyboy
Message 5 of 11
Re: No connection
had no connection for 24 hours now. not acceptable at all
  • 3.01K
  • 383
  • 952
Message 6 of 11
Re: No connection
Have you called VM and reported the fault?
______________________
Scott
  • 82
alyboy
Message 7 of 11
Re: No connection
just spoke to someone on live chat, was told there is a fault and it's being worked on and should be done any time between now and 2pm. hopefully it gets sorted
  • 82
alyboy
Message 8 of 11
Re: No connection
well so much for it being fixed by 2. still down
  • 55
lyonc
Message 9 of 11
Re: No connection
I've had the same problem randomly over the past few weeks but it only lasts a minute or two. Try using a different cable if you have one, (the cable that goes from your router to the box on the wall) because it might be damaged and that's what's causing the problem
  • 82
alyboy
Message 10 of 11
Re: No connection
right so apparently after telling me my internet would be working by 2pm today, they now told me they need to send an engineer out... next wednesday! so i'll be without any service for over a week. great company
