MJW2
No cable down my road
The virgin website says that there is virgin cable down my road. But i am not sure there is at the bottom of the road because it becomes a private road. I just want to double check that it is possible for me to get virgin media.
  • 7.36K
  • 830
  • 3.1K
Re: No cable down my road
You won't know until to ask VM directlyn (0345 454 1111) or by using the post code checker - though that can be dodgy.
http://www.virginmedia.com/shop.html
Superuser 2017/18
Use Kudos to say thanks
Mark answer as "helpful" only when the problem is solved
Please don't send me private messages unless I ask you to.
I do not work for VM. The advice I give is based on my best understanding of VM policy and practice. You rely on it at your own risk.
