Pablo1919
Message 1 of 5
No WPS pin on super hub 3
Trying to access the VM browser page to change my ssid name and i am being asked for the settings password and wps pin.
The settings password is clearly shown on the base of the hub 3, however there is no sign of a wps, and without it i cant change any settings.
Can anyone help?
thanks
Pab
  • 17.66K
  • 1.65K
  • 3.08K
Message 2 of 5
Re: No WPS pin on super hub 3
The Hub 3.0 administration login only asks for the Settings password.
If you're being asked for a password and a WPS PIN then that's a login for an older Super Hub.
I'd double check you're connecting to the Hub you think you are!
Pablo1919
Message 3 of 5
Thanks for that Ben.
On the bottom of the hub it says hub 3.0 so im not sure why it is still asking for a wps pin.
The equipment only arrived yesterday and i was told i would be receiving the latest equipment (despite the tivo box looking as the one i had a couple of years ago!!)
Thanks in advance for any help.
  • 17.66K
  • 1.65K
  • 3.08K
Message 4 of 5
This is the login page for the Hub 3.0 - it only asks for one password
So this is the page you should be seeing. If you're seeing anything else, then you're not connecting to the Hub 3.0. Double check that you've connected to the same Wireless name as shown on the bottom of the Hub 3.0.
Pablo1919
Message 5 of 5
Cheers again Ben.
Tried today and i got the screen as you just posted above. No idea why, but its sorted now.
Thanks for your assistance.
Pablo
