Angariel69
Message 1 of 8
No WIFI but wired ok
Okay,
Started about 2 hours ago.  All of my Wifi devices (phone, tablets, Firestick) are constantly dropping connection, and I'm talking about every few seconds.
I have tried rebooting the Modem with no success and I cannot access the settings on my Hub via my wired PC (which is constantly connected and showing no dropouts at all).  The trusty 192.168.1.1 is timing out.
I have no new equipment, I have not moved the modem.  Nothing has changed at my end.  I appreciate that trouble shooting Wifi issues can be a problem but in the last 9 months I have been fine, as have both my wired and wireless connections.
Hub broken?
Helpful Answers
  • 286
  • 27
  • 62
Andrew-H
Fibre optic
Message 2 of 8
Re: No WIFI but wired ok
The address for the hub will be 192.168.0.1 to change the settings.
These are just my opinions. Feel free to completely ignore my advice. The above message may contain sarcasm (if you can't find it, you're not looking hard enough)
All Replies
  • 286
  • 27
  • 62
Andrew-H
Fibre optic
Message 2 of 8
  • 1.28K
  • 96
  • 236
stevedh2
Knows their stuff
Message 3 of 8
Have you tried using a wifi scanning app to see if you're maybe getting conflicts with neighbours, and I assume you haven't recently got a baby monitor or any other device that could interfere with your wifi.
Angariel69
Message 4 of 8
No baby monitors (or anything electrical), I have tried changing channel, security mode and passphrase
Currently getting 30Mb over wired, and when it finally connects 0.17Mb over wifi
Tearing my hair out here
  • 7.59K
  • 188
  • 442
Message 5 of 8
Hi Angariel69,
Welcome to the forums, I am sorry to see you have been having trouble with your connection.
I have taken a look and things seem to be ok from this side.
Try Getting the best Wireless Network Signal and let us know if it makes a difference.
You should be on 100Mb at least on the wired connection so I would also like to see a BQM so I can get a better idea of what you are seeing from your side.
Speak to you soon.
Emma
Angariel69
Message 6 of 8
I tried multiple re-starts of the Hub but the problem corrected itself the following day without any further intervention.
The problem lasted about 10 hours, there was nothing new connected to the equipment, I changed the wifi password and re-booted - only time fixed it so not sure what the problem was.
  • 7.59K
  • 188
  • 442
Message 7 of 8
Hi Angariel69,
Thanks for getting back in touch, I am glad to see things are looking better for you now.
I have tried to take another look to see if there was any new information on the systems but I am currently unable to locate your connection details.
If you would like me to try to investigate further please reply to the PM I am about to pop across to you. Keep an eye out for the Purple Envelope top right hand corner.
Speak to you soon.
Emma
marks148
Just joined
Message 8 of 8
I have the same issue. 200mbps wired and 5 bar wifi signal , just no internet over the wife at all, for nay device. It has done it from time to time over the last couple of years but normally only for a few seconds. it seems odd to get the full wife signal but no connection to the web
