CM1967
Neighbours BT HUb
Can you help, since my neighbour installed a BT Hub my wireless signal keeps dropping out. Cable connection is fine but the wireless signal of the BT Hub seems to overpower the virgin media wireless signal.
Any help people?
  • 16.46K
  • 1.37K
  • 3.36K
Re: Neighbours BT HUb
hiya @CM1967 you could look at changing wireless channels guide -> http://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=27539&CURRENT_...
CM1967
Thanks. I have two wi-fi channels on the hub, so I've set all devices to the other channel to see if that helps. I'll let you know.
