  • 12
MrsBreezy
Message 1 of 5
Need help
I have a bit of a problem, since I've upgraded my broadband to superhub I now cannot use my wireless printer and because my printer is wireless I can't use a USB to print stuff I cannot even access my scanner and it's very frustrating my printer worked on my old broadband fine but now it's not working and I need my printer! Any ideas why it's suddenly not working since I've upgraded my broadband ?
Many Thanks People
Helpful Answers
  • 16.48K
  • 1.37K
  • 3.36K
Message 3 of 5
Re: Need help
hiya @MrsBreezy what printer do you have, and what hub you do have?, does the printer detect the wifi connection?, do you get any error messages etc.
All Replies
  • 22.23K
  • 845
  • 3.23K
Message 2 of 5
Re: Need help
you will need to set your printer up on the new wireless network. you may need the printers install CD and a USB cable for this. Check the printer manuals for how to do this.
  • 16.48K
  • 1.37K
  • 3.36K
Message 3 of 5
Re: Need help
  • 12
MrsBreezy
Message 4 of 5
Re: Need help
I have epson xp-202 when I purchased the printer it came with the printer CD and the power supply and when I tried syncing my printer to the hub it's not working I've searched online for answers and I've seen many saying since they've upgraded to superhub their printer stopped working
  • 22.23K
  • 845
  • 3.23K
Message 5 of 5
Re: Need help
that will be becuase peole have not set the printer up with the new wireless,
ftp://download.epson-europe.com/pub/download/3739/epson373975eu.pdf
Check from stage 3 to connect it. if you need the software if you have lost the CD you can get it from https://www.epson.co.uk/products/printers/inkjet-printers/consumer/epson-expression-home-xp-202#driv...
