Steveski
My wifi signal is weak.
recently joined virgin and the engineer stated that the signal would be strong throughout my bungalow. However I have no signal in one of the rooms. Is there a plug in booster available. Thanks
  • 27
  • 5
mrpops2ko
Re: My wifi signal is weak.
I'd suggest buying a 3rd party router like the Asus RT-N66U you can get it for like 30 quid off well known auction websites.
Then just use the Super Hub in modem only mode.
