Alat139
Message 1 of 7
My Hub 3 will not work on start up each morning.
This has got progressively worse over the last few weeks. I now takes 20/30 minutes before it rectifies itself. I operate an iMac and an iPad and both are affected.
  • 20.72K
  • 553
  • 3.21K
Sephiroth
Message 2 of 7
Re: My Hub 3 will not work on start up each morning.
Maybe you could post your modem stats to see if it's a circuit issue.
192.168.100.1. And click CHECK ROUTER STATUS
Then copy/paste the upstream & downstream power levels and the network log.
It takes the VM bods at least a week to get to a thread so we might as well triage.
Alat139
Message 3 of 7
Do I just paste 192.168.100.1 into the browser? It just said Safari cannot find the swerver.
Alat139
Message 4 of 7
Cannot find the server, of course!!
  • 20.72K
  • 553
  • 3.21K
Sephiroth
Message 5 of 7
Then please try 192.168.0.1
You need to be sure that you are indeed connected wirelessly or wired to the Hub 3.
Alat139
Message 6 of 7
This may be the solution to my problem.
During regular vacuuming the Hub 3 was knocked to the ground by accident. Since then I have not had a repeat of the problem mentioned.
  • 8.29K
  • 354
  • 582
Message 7 of 7
Hi Alat139,
Welcome to the Community!
Good to hear you've found the cause of the problem! Is everything working OK now?
Speak soon Smiley Very Happy
Josh
