dianedarlo
Moving wifi hub to another room
Is it possible to move the wifi hub to another room? Which department do I contact and how much will it cost?  Can the hub be located next to the television?
Helpful Answers
  • 8.62K
  • 552
  • 2.38K
Re: Moving wifi hub to another room
You can call VM and ask them to move it. That will cost you 99 quid, as its elective work.
Ive had some success with getting them to move HUB whilst doing other work (for example installing a TiVo box) so it might be worth exploring your options with the retention's team , especially if you are out of contract.
All Replies
  • 8.62K
  • 552
  • 2.38K
