  • 6
Nucroos
Lower Speed on Super Hub 2 on the 5Ghz channel
I am on the 152 Mbps connection and since the last month, i am only getting around 70 Mbps whilst on the 5Ghz channel. This happens with two mobile phones one android and one Microsoft. Laptops connected to the 2&5 Ghz channel are getting speeds of over 100 at least. Very baffling as to why suddenly i have this issue and wanted to ask if anyone knew of any possible fixes/solution for this?
  • 1.87K
  • 175
  • 338
J0hn
Super solver
Re: Lower Speed on Super Hub 2 on the 5Ghz channel
Is it "suddenly". Or the first time you have checked?
have you looked into the settings on the phones and seen what they are set to 2.4, 5 or auto?
Or auto then clear out the cache
if 5Ghz
  • 1.87K
  • 175
  • 338
J0hn
Super solver
Sorry I had editing issues and it timed out on my
I'll rewrite all aftersee what they are set to 2.4 or 5 Ghz
To check on android
Settings, wifi, three dots top right, advanced, wifi frequency band, choose auto or 5 Ghz
  • 6
Nucroos
Hi John,
Thank you for taking the time out to reply. Firstly, the issue has been persistent for the last 3-4 weeks, before that; i used to always have speeds of upwards or 100 mbps as a minimum on the 5 Ghz. Secondly, i still am on the 5 Ghz and always double check to make sure i am always on the 5Ghz frequency.  It is a bit flabbergasting as to the reason why i am having speeds of almost half of what i should be receiving?
