  • 6
StephenBl
Message 1 of 7
Loss of connection and slow speeds.
Hey there we have been having issues with our internet recently with slow speeds and total loss of internet happening fairly regularly.
I noticed it a couple of days ago and it's gotten progressively worse. It started with T4 timeouts and now it's T3 timeouts.
Here is the log:
5da43efb0392a82adcda53a2f4a23ec9
Our speeds are usually 220 download and 12 upload but it's jumping up and down around 100 download and 3 upload.
Look forward to hearing a reply thank you.
  • 16.52K
  • 1.38K
  • 3.38K
Message 2 of 7
Re: Loss of connection and slow speeds.
hiya @StephenBl rather high amount of T3 issues, could you post the downstream/upstream and operational config details.. also with the connection is this wired/wireless?
  • 6
StephenBl
Message 3 of 7
Hey paultechy thanks for replying here are the downstream/upstream details:
f8fbaa16368a04beecd303c0428753eb
Where do I find the operational config details?
The connection is wired.
  • 6
StephenBl
Message 4 of 7
Found the page:
f9dace1bfefcf6c4ae0909b75a8ce0bb
Here are the upstream and downstream on the same settings page:
Downstream:
ad0d634a4d22de79536604dce4edfae3
Upstream:
35312ddff9b71127a543d3f0a7edcf6a
  • 16.52K
  • 1.38K
  • 3.38K
Message 5 of 7
your PostRS errors are extremely high, the preRS not much of issue.. if you reset the counters do they still increase into massive numbers, since this could caused by so many issues, would really need to be checked bt broadband support or via forum team which can take around 5+ days.
  • 6
StephenBl
Message 6 of 7
Here are the results after resetting the Post RS Errors:
Just as I reset at 11:25:
e9031130c7f31a7d1801ccd112ef79df
After 2 hours at 13:25:
a72154f2ffe683e6733d22abaae1424f
  • 10.82K
  • 308
  • 632
Message 7 of 7
Afternoon StephenBI,
Sorry to read you are having issues with your broadband connection.
From checking your connection, the upstream power levels have risen to 53 dBmV and for this I would like to arrange for an engineer appointment to check this over. I've sent you a PM (purple envelope icon, right corner) with some details for you to confirm please.
Hope to hear from you soon
Sam
