  • 8
uc_india
LifX bulbs + SuperHub settings
Trying to connect LifX bulbs using SuperHub2, no success so far. Bulbs detect and work fine with a WifiHotspot using mobile data. As far as SH2 goes, bulbs don't detect the wifi SSID at all. Looking at the other forums i have done reset, played with various settings, channels etc... no success. Help appreciated.
  • 6.1K
  • 345
  • 1.01K
Re: LifX bulbs + SuperHub settings
Make sure your using Channels 1 - 11 only 2.4Ghz and you must use WPA2 Security Only.
They do not support 5Ghz. WEP, WPA or channels 12 or higher on 2.4Ghz.
200Mb(SH2 SH2AC Hub 3.0), 2 X V6 TV XL, Phone M. 100Mb Business (Hitron Hub).
  • 8
uc_india
Thank you. I have tried all that without success so far. One thing I noticed now: Bulb onboarding goes through OK within seconds of router restart, soon after that *something* kicks in and bulb is lost. I am wondering some firewall/router rules that kicks in? (a theory)
All according to how LifX wants - 5GHZ is disabled permanently, 2.4Ghz channel, Security... everything pretty much. Other connected devices (Speakers, Nest, Piper) working OK. Reading some other thread - i tried setting up a guest network as well - no success.
  • 6.1K
  • 345
  • 1.01K
The firewall on the super hubs have been known to interfere with internal traffic but should not cause a wifi disconnect. The firewall can be disabled in the Superhub settings.
