CMD2
Laptop not connecting to superhub2 wifi
I've just bought a new Lenovo ideapad 100s, running Windows 10 - but it won't connect to the wireless network, even using WPS. I've connected 4 other laptops previously, as well a number of iPhones, android phones, iPads and other wireless devices - but this specific laptop seems to resist. The laptop will connect to other public and private networks however - so I don't believe it is a fault with the computer.
any help would be great, thanks.
Chris
  • 14.47K
  • 641
  • 1.46K
Moderator
Moderator
Re: Laptop not connecting to superhub2 wifi
Hi CMD2,
Welcome to the forum and sorry to hear you're having trouble connecting your ideapad to the hub. I'd first of all suggest logging into the hubs config pages and changing the wireless security type to WPA2 PSK AES. Some devices can have trouble with the default WPA2 Auto.
Give this a try and let us know how you get on.
