Nottslad74
LRT224 Connection through Hub 3.0 in Modem mode issues
Hi All,
        I am trying to build a VPN at home and as a first step I have set up the Hub 3.0 as a Modem and plugged a TP-LINK Wireless router to it and it works fine.. the TP-link gets the IP address from the Hub 3.0 and routes fine, however when I use the LinkSys LRT224 VPN router, it doesn't pick up the address from the Hub 3.0. through "Obtain Ip Address dynamically" option in the WAN configuration of the router. Anybody out there who has had the problem before please?
  • 9.42K
  • 317
  • 1.02K
Re: LRT224 Connection through Hub 3.0 in Modem mode issues
Hello Nottslad74
Welcome to our forum, I wonder if the Linksys is not getting an IP because one has been issued to the TP link already. The hub will only give it to one device and will require a proper DHCP relinquish or reboot to allow a new device to get it. Hope you managed to get it going eventually.
Thank you
Nicola
Virgin Media Forum Team
  • 1.3K
  • 65
  • 236
Knows their stuff
I would think you will need to have the LinkSys LRT224 VPN router as the only router in your setup.
The other TP Link should be setup as an access point to provide wireless access only.
This should work as it's similar to my own setup at home.
Nottslad74
The lrt224 doesn't pick up an ip address when it's connected on its own directly to the virgin 3.0 hub in modem mode. When I tried a different machine like the cheap wireless router it does. Any idea of why please? I have read on the internet that it might be an issue with the dhcp variant that the hub 3.0 provides, is there a work around ?
