RowlandHill
Message 11 of 60
Re: L2TP/IPSec VPN Issue With Hub3.0
I have the same problem
our company has been upgraded to hub 3 and low l2tp connections are not getting through
  • 14
  • 7
georgebell
Message 12 of 60
I have cooled down a little, but am totally shocked (albeit grateful) to see this thread having already wasted a great deal of time of late endeavoring to use L2TP to access our Windows Server 2016 from home via a Virgin Hub 3.  I cannot believe the issue has been around for so long!!
A very long support call with Bombay or Delhi last night, where I was told to hold in the reset for FORTY seconds and then wait 4-5 minutes for the Hub to reboot was no joke.  And indeed I don't believe the "support" rep even knew what "L2TP" was!
Has anyone had any success tackling Virgin, or are they simply all away playing Ostrich on Richard's island?
I for one will certainly be contacting the Consumers Association (Which?).  In this day and age where we are all being advised to increase our internet security, it is crazy that Richard Branson and his cronies are actually preventing that security from being implemented.
  • 9
Australian
Message 13 of 60
The only problems i am having with my service originate with the Hub itself.
Virgin, if i am forced to run in modem mode, can you please supply me with a second router (not a hub) so that i can use this connection for the reasons i am paying for it?
  • 14
  • 7
georgebell
Message 14 of 60
And the same goes for me please!
You might want to add your own comments to mine in a message to Daniel Booth, Editor of "Computer Active" magazine - ############## with Subject: "Should you chuck your Virgin Media Router?"
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 12.61K
  • 357
  • 1.46K
Message 15 of 60
Hi to all on this thread,
Sincere apologies for the issues you're having with VPN. The team responsible for the firmware for our Hubs have confirmed that there are no VPN issues with our HUB 3.0. The PPTP VPN issue was fixed long back and all VPN should work as expected.
To allow us to investigate what's happening may we please have the below information:
  1. Are you able to use VPN with modem mode enabled on the Hub and (if possible) a 3rd party router connected?
  2. What VPN protocol is failing (L2TP/IPSec / PPTP / etc … )?
Please also send me a PM with the following info:
  • Your modem MAC address
  • Or your house number and postcode
Many thanks,
Jen
  • 22
hooper35
Message 16 of 60
Did anyone manage to get L2TP/IPSec to work with a Superhub in Router mode? I still cannot connect my Windows 10 client BUT I can connect an Android phone.
I have tried the Registry change (AssumeUDPEncapsulationContextOnSendRule), but that does not help.
Charles
  • 14
  • 7
georgebell
Message 17 of 60
Hi Jen,
I'd happily send you a PM, but the link in your message appears to go nowhere.
I'm obviously more than reluctant to give out the information you require on the list.
George
Scottmcmullan8
Message 18 of 60
Can you help me with this one too? I need to be able to use this as I work from home and need to use VPN - can you PM me the settings to allow this to work?
  • 22
hooper35
Message 19 of 60
I gave up on this and put the router in modem mode.
I concluded the super hub software does not have the capability to let the L2TP protocol through.
You will not be able to set up an L2TP/IPSec VPN when the router is in router mode.
It's a bit rubbish really.
Charles
Scottmcmullan8
Message 20 of 60
Quite sad and pathetic really
Sad because VM broadband is the most reliable and fastest I have used so it's a shame this missing feature lets a lot of users down - especially with working from home being so rife.
Pathetic because I see posts going back since last year regarding this issue and still no fix except put your hub into modem mode.  BTW I work in IT and provide support and create Cisco VPN configurations for our users so I can't wait to tell them the brilliant news!
