RECS
Kindle Voyage will not hold a connection to SH
Hi I have several Amazon products and in the main it is fine - however my Kindle Voyage will not stay connected - I either have to switch off the entire network and then connect it or I have to disable all security and then connect and then of course I have to re-establish the security !
It's driving me mad any help will be much appreciated.
  • 10.82K
  • 308
  • 632
Re: Kindle Voyage will not hold a connection to SH
Hi RECS,
I'm sorry to read of the issues you are experiencing with your Kindle Voyage.
Does the device connect to the 2.4 GHz or the 5 GHz network?
In regards to the security, does that show as different on the device itself or within the router settings?
How often does this happen?
Let us know how you get on
Sam
