Echbirb
Issues with Port Forwarding on 3.0 Hub
Hey, I'm a long time Virgin Media customer and have had little to no issues with my connection until recently.
After upgrading to the new 3.0 Hub I have been having many issues with the hub from not allowing any port forwarding to only allowing one port per IP to even randomly shutting down and having to be restarted.
As well as my speeds being very unreliable at some times this worries me about the reliability of my internet connection.
To have more than one port forwarding rule per local IP I have been forced to buy another network card so I can port forward properly.
My Port Forwarding Config, and what happens when I try to access the page remotely. Nothing even hits the web server, the router most likely is blocking this without showing anything or Virgin media is blocking the port on the backbone level. My other port forwarding rule is respected by the Hub and works perfectly. For note, accessing via local IP works just fine.
If anyone has any suggestions to help I would greatly appreciate it.
Helpful Answers
  • 14.1K
  • 753
  • 4.94K
Re: Issues with Port Forwarding on 3.0 Hub
First off lets deal with this statement
Here's my port forwarding rules
Note: I have rules for the following all on the same PC
Web Server
FTP Server
Teamspeak
And one other which is a service running on a non standard port (deliberately)
There is an annoying bug which means that rules must be entered in ascending order, so if I wanted to port forward Port 25 for example, I'd have to delete the rules above port 25.  Add the port 25 rule and then re add the other rules again.
Tim
________________________________________
Only use Helpful answer if your problems been solved.
All Replies
  • 14.1K
  • 753
  • 4.94K
Web Server
FTP Server
Teamspeak
Tim
Echbirb
Reordering my port forwarding rules seems to have fixed the issue, thanks for quick help
