BRubble
Just joined
Is it possible to turn Virgin broadband connection off or on remotely or with a timer?
I'd like to have more control over my children's access to WiFi / broadband by controlling when they use it. Is this possible through some sort of timer?
  • 16.52K
  • 1.38K
  • 3.38K
Re: Is it possible to turn Virgin broadband connection off or on remotely or with a timer?
hiya @BRubble welcome to the virginmedia community forum, yes you can guide -> http://community.virginmedia.com/t5/Switched-On-Families/Set-internet-time-limit-for-child/td-p/3138... takes a bit of time to setup
