  • 28
  • 5
mrchannell
Is it possible for me to replace my HUB 3 with a different router?
I get occasional lock ups to the internet and read that changing the router might help?
Is it possible for me to replace my HUB 3 with a different router?  If so what can I replace it with?  What should I be looking for?
Thanks in advance.
Leslie
  • 546
  • 42
  • 84
DavidJWalker
Rising star
Re: Is it possible for me to replace my HUB 3 with a different router?
you can put it in modem mode and use your own router thats only way you can do it or ring up and try and get superhub 2ac from virgin media not online from ebay or any other online store
Using VIVID 350 Optical Fibre, Player TV, Talk Weekends
Just another VM user trying to help out so my answers may be wrong.
If you do like my answer please mark it as helpful; it may help others
