wolfyccfc
Ipad connection issue to 5ghz
As from this morning i have had problems with the 3 ipads in the house connecting to the internet, it is only ipads, all iphones and macbooks connect ok. I have eventually pinned it to the 5ghz setting as when this is switched off all ipads work ok, switch it on and they stop connecting to the internet. As this has occurred all of a sudden is this a router issue or has a firmware /software update occurred on the router overnight which has affected this?
thanks for your help.
  • 10.82K
  • 308
  • 631
Re: Ipad connection issue to 5ghz
Hi there wolfyccfc,
Thanks for posting on the community. It's nice to have you here.
Sorry to read that you are having an issue with connecting your iPads to the wireless network.
Are you still having the same issue since you posted?
Do all the iPads connect to the 2.4 GHz network or do some connect to the 5 GHz also?
Have you tried to change the wireless channel or security to WPA PSK to see if that helps?
Let me know how you get on
Sam
