  • 5
SteveBuck
Message 1 of 8
Intermittent wireless signal
I have recently been experiencing flaky wireless performance from my Super Hub.
I've followed the "getting the best wireless network signal" tips and repositioned the hub, changed channel to AUTO and changed frequency to 5GHz.
Initially this seemed to help but then signal weakens or periodically drops completely for a short while.  SpeedTest.net results show download speeds up to 50M but then sometimes down to single figures.  The performance is rendering an Amazon Firestick useless as it keeps buffering and losing network.
Thanks in advance!
Helpful Answers
  • 2.96K
  • 378
  • 939
Message 4 of 8
Re: Intermittent wireless signal
Probably best to try some wired tests first to see if the speed is being delivered to the hub reliably before exploring wireless options.
Having said that, the 5Ghz band is less congested and faster but not as good at penetrating walls as the 2.4GHz band so that might be a factor.  Powerline adapters are usually a good way to improve wireless around a property.  They use the electrical wiring in your house to create a wired network without the need for long cables.  They are rarely as fast as the manufacturer's claim but are a lot more stable and less prone to interference than wireless.  Some provide just wired connections and others come with additional wireless built in to allow you to create a wireless access point in parts of the house where the wireless signal is poor.   Some powerline adapter reviews here:
http://www.pcadvisor.co.uk/test-centre/network-wifi/20-best-powerline-adapters-2016-uk-3490638/
______________________
Scott
  • 2.96K
  • 378
  • 939
Message 7 of 8
Hi Steve
if you are having to choose between 2.4Ghz and 5Ghz on the router rather than both simultaneously I'm guessing you have the original Superhub which doesn't support dual band wireless and is notorious round these parts for providing poor wireless.
You can try calling VM and see if they can replace your hub with a more recent one, although the current Hub 3 is not guaranteed to resolve your issues as that has had issues with Amazon Firesticks in the past.  If you call in and take the "Thinking of leaving us option" to get through to the retentions team (don't worry they do a lot more than just process cancellations) and point out how bad the wireless is on your old Superhub they might be able to sort out a new hub.
You could buy your own router and put the Superhub into modem mode.  It is what I and many others have done and has improved my wireless performance immensely.
Scott
All Replies
  • 2.96K
  • 378
  • 939
Message 2 of 8
Have you checked with an Ethernet connected device to make sure the hub is still getting the full speed?  If wired speeds are also slow then it isn't just a wireless issue and suggests a possible line fault.
Are you seeing slow speeds all day or only at peak times (typically 4pm-11pm weekdays and weekends)? Some areas are suffering with over utilisation, which results in very slow speeds at peak times but full speed at off peak times.
Scott
  • 5
SteveBuck
Message 3 of 8
Hi Scott
Thanks for your response
I will perform some tests with Ethernet wired.  We don't use the service so much during the day, it's more peak times so not sure about the over-utilisation possibility, I'll try to test this when possible.
Something else I realised, which doesn't help the wireless signal to the rest of the house, is that the hub and the main PC are in a small study which was added as an extension to the house before we moved here.  I've noticed that the wall between the study and the rest of the house, which the wireless signal has to penetrate, used to be the outside wall so is double-brick!  I'm now wondering what my best option is to get a another hub/repeater or some way to transmit a good signal to the main house, without necessarily moving the hub from the study, as then this room will have a weak signal.  So basically its as if I have the hub outside my house !  (Having said that I still see wide variations in service even directly next to the hub).  Any suggestions gratefully accepted, cheers.
  • 2.96K
  • 378
  • 939
Message 4 of 8
Scott
  • 5
SteveBuck
Message 5 of 8
Hi Scott,
Just tried 3 consecutive tests using a PC wired and another wireless ...
Wired gave download speeds of 50, 46 & 45 MB
Wireless done at exactly the same time gave 15, 14 & 16
Not sure whether that's a bigger differential than expected
(PS I've now changed the router back to 2.5 GHz as my wireless printers didn't seem to support 5 GHz)
Cheers,
Steve
  • 5
SteveBuck
Message 6 of 8
... another 3 test 1/2 hour later and the drop in Wireless performance is significant
Wired 50, 50 & 53 Mbps
Wireless 5, 6 & 16 Mbps.  This PC is directly next to the hub.
This is fairly typical of the variations I am seeing.  Looks to me as if its the wireless signal dropping not the wired service.
The hub is fairly old, wondering whether I should be suggesting a replacement ?
  • 2.96K
  • 378
  • 939
Message 7 of 8
Hi Steve
Scott
  • 5
SteveBuck
Message 8 of 8
Cheers Scott
Thanks for all your great help
