  • 6
IoanRsx
Message 1 of 12
Intermittent service both wired and wireless
Cute right?
So, just to make a long story short - I'm very dissatisfied with VM's Internet service. Initially, over the last 5-6 months, I've been experiencing random disconnects (1-2 per day), the internet being down for about 4-5 minutes. I work in IT so I've performed most troubleshooting steps I could think about in that time, without success. It just works when it wants to. :-) While annoying, it wasn't annoying enough for me to report it and I could actually live with it but...
Now, I'm getting an intermittent connection every 30 seconds to 2 minutes intervals. The connection drops down to 8kbps or even 0kbps (disconnecting altogether) once about 5 minutes lasting, as I mentioned 30 seconds or even 2 minutes.
There are several devices in the house: 1 wired and 4 wireless and they are all experiencing the same issue. No configuration changes have been made to the router since the installation. The router's reset doesn't seem to affect the intermittent connection whatsoever.
I've been on the phone with someone from Technical Support and after explaining the issue and the troubleshooting steps, he "checked" and said there are works being done in my area and that there's nothing I can do (Turpike Lane area, London, N8) because I'm going to have intermittent connectivity loss until the 26th - the earliest. His tone wasn't very confident and adding the fact that there's nothing announced on the website when I enter my postcode makes me think (and hope) there's something else at fault here that can be fixed sooner.
Please let me know if you need any further logs and stuff. Thanks.
Ioan.
  • 6
IoanRsx
Message 2 of 12
Re: Intermittent service both wired and wireless
Logs from the router:
Information
Cable Modem
EuroDOCSIS 3.0 Compliant
Serial Number
483152WS136AF
Boot Code Version
PSPU-Boot 1.0.20.1391
Software Version
V1.01.11
Hardware Version
1.03
CA Key
Installed
Cable Modem Status
Item
Status
Comments
267000000
Locked
Ranged Upstream Channel (Hz)
46200000
Success
Provisioning State
OK
Operational
Downstream
DS-1
DS-2
DS-3
DS-4
DS-5
DS-6
DS-7
DS-8
Frequency (Hz)
267000000
N/A
283000000
291000000
299000000
307000000
315000000
323000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)
Locked
Unlocked
Locked
Locked
Locked
Locked
Locked
Locked
Channel ID
3
N/A
5
6
7
8
9
10
Modulation
256QAM
Unknown
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
Symbol Rate (Msym/sec)
6.952000
N/A
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
Interleave Depth
I=12
J=17
N/A
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)
17.40
N/A
17.47
17.60
17.75
17.64
17.67
17.82
RxMER (dB)
34.93
N/A
33.38
33.60
34.93
34.77
34.93
35.08
Pre RS Errors
158776
N/A
267957
304942
227314
228135
229789
227096
Post RS Errors
124277
N/A
132723
153800
154209
153296
155887
158651
Upstream
US-1
US-2
US-3
US-4
Channel Type
2.0
N/A
N/A
2.0
Channel ID
73
N/A
N/A
75
Frequency (Hz)
46200000
N/A
N/A
32600000
Ranging Status
Success
Other
Other
Success
Modulation
64QAM
N/A
N/A
64QAM
Symbol Rate (Sym/sec)
5120000
N/A
N/A
5120000
Mini-Slot Size
4
N/A
N/A
4
Power Level (dBmV)
35.75
N/A
N/A
35.25
T1 Timeouts
0
0
0
0
T2 Timeouts
0
0
0
0
T3 Timeouts
192
0
0
172
T4 Timeouts
0
0
0
0
Upstream Burst
Req
(1)
Init Maint
(3)
Per Maint
(4)
Adv Short
(9)
Adv Long
(10)
Adv UGS
(11)
Modulation Type
QPSK
QPSK
QPSK
64QAM
64QAM
64QAM
Differential Encoding
OFF
OFF
OFF
OFF
OFF
OFF
Preamble Length
56
640
384
104
104
104
Preamble Value Offset
652
0
0
716
716
716
FEC Error Correction (T)
0
5
5
12
16
12
FEC Codeword Information Bytes (K)
16
34
34
81
223
81
Maximum Burst Size
0
0
0
11
193
219
Guard Time Size
8
48
48
8
8
8
Last Codeword Length
Fixed
Fixed
Fixed
Shortened
Shortened
Shortened
Scrambler On/Off
ON
ON
ON
ON
ON
ON
General Configuration
Network Access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
EuroDOCSIS 3.0
Config File
SFID
11602
Max Traffic Rate
57500000 bps
Max Traffic Burst
10000 bytes
Min Traffic Rate
0 bps
Primary Upstream Service Flow
SFID
11601
Max Traffic Rate
3170000 bps
Max Traffic Burst
16320 bytes
Min Traffic Rate
0 bps
Max Concatenated Burst
16320 bytes
Scheduling Type
Best Effort
First Time
Last Time
Priority
Error Number
Description
20/11/2016 17:31:13 GMT
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
  • 9.47K
  • 649
  • 1.81K
Message 3 of 12
downstream is a mess - the levels are far too high and one channel is not there - not got my upstream head on but from memory they are too low - regardless unless its an area fault you need a tech - will flag the thread which hopefully will get VM to it a bit quicker for them to book a tech
____________________
Tony
  • 10.82K
  • 308
  • 631
Message 4 of 12
Hi Ioan,
My apologies that you are experiencing intermittent broadband connection.
Looking at your connection, there is an SNR (signal to noise ratio) fault reported in your area which is causing intermittent connection. The reference number is F004890131 and with a review date of today.
As -tony- mentioned there is an issue with the downstream power levels. After the fault has been closed down as resolved, I will check this over again and if there is still an issue with the power levels we can arrange an engineer appointment.
Will speak to you soon
Sam
  • 6
IoanRsx
Message 5 of 12
Hi Sam,
Thank you very much for the reply.
I would be really nice if I could get an ETA on this as a stable connection is very important for my work. Also, can the upstream / downstream values can be adjusted remotely from your side? Thanks.
Ioan.
  • 10.82K
  • 308
  • 631
Message 6 of 12
Hi Ioan,
With the SNR fault you can check the progress on our Service Status page. I will also check this when I am in the office this evening.
In regards to the downstream/upstream power levels, only an engineer will be able to adjust these to the correct ranges as we are unable to do this from our side.
Speak soon
Sam
  • 10.82K
  • 308
  • 631
Message 7 of 12
Evening Ioan,
Only me.
Looking at the SNR fault, this is now showing as closed.
I wanted to check the power levels to see if they were still showing as too high, however the Super Hub is showing as offline?
Is the router turned off as not in use? Are you able to re-post your router information for us please?
Hope to hear from you soon
Sam
  • 6
IoanRsx
Message 8 of 12
Thenk you for your reply. Sorry I couldn't respond sooner but it's been working so bad today, I couldn't even post (maybe that's why it was showing as offline)... Smiley Sad Anyway, here are the logs (I can see some change in the downstream - I have one extra channel that was previously disabled):
Information
Cable Modem
Serial Number
483152WS136AF
Boot Code Version
Software Version
V1.01.11
Hardware Version
1.03
CA Key
Installed
Cable Modem Status
Item
Status
Comments
267000000
Locked
46200000
Success
Provisioning State
OK
Operational
Downstream
DS-1
DS-2
DS-3
DS-4
DS-5
DS-6
DS-7
DS-8
Frequency (Hz)
267000000
251000000
259000000
275000000
283000000
291000000
299000000
307000000
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Channel ID
3
1
2
4
5
6
7
8
Modulation
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
Interleave Depth
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)
17.96
17.78
17.85
18.01
18.11
18.21
18.37
18.22
RxMER (dB)
35.42
35.08
35.25
33.27
34.63
34.77
34.77
34.63
Pre RS Errors
62289
64828
64160
132342
101824
96035
91000
96516
Post RS Errors
48063
47650
47008
74953
70026
64727
59665
65134
Upstream
US-1
US-2
US-3
US-4
Channel Type
2.0
N/A
N/A
2.0
Channel ID
73
N/A
N/A
74
Frequency (Hz)
46200000
N/A
N/A
39400000
Ranging Status
Success
N/A
N/A
Success
Modulation
64QAM
N/A
N/A
64QAM
5120000
N/A
N/A
5120000
Mini-Slot Size
4
N/A
N/A
4
Power Level (dBmV)
34.50
N/A
N/A
34.75
T1 Timeouts
0
0
0
0
T2 Timeouts
0
0
0
0
T3 Timeouts
39
0
0
37
T4 Timeouts
0
0
0
0
Upstream Burst
Req
(1)
Init Maint
(3)
Per Maint
(4)
Adv Short
(9)
Adv Long
(10)
Adv UGS
(11)
Modulation Type
QPSK
QPSK
QPSK
64QAM
64QAM
64QAM
OFF
OFF
OFF
OFF
OFF
OFF
Preamble Length
56
640
384
104
104
104
652
0
0
716
716
716
0
5
5
12
16
12
16
34
34
81
223
81
Maximum Burst Size
0
0
0
11
193
219
Guard Time Size
8
48
48
8
8
8
Fixed
Fixed
Fixed
Shortened
Shortened
Shortened
Scrambler On/Off
ON
ON
ON
ON
ON
ON
Network Access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
EuroDOCSIS 3.0
Config File
SFID
17746
Max Traffic Rate
57500000 bps
Max Traffic Burst
10000 bytes
Min Traffic Rate
0 bps
SFID
17745
Max Traffic Rate
3170000 bps
Max Traffic Burst
16320 bytes
Min Traffic Rate
0 bps
16320 bytes
Scheduling Type
Best Effort
First Time
Last Time
Priority
Error Number
Description
21/11/2016 19:33:24 GMT
Critical (3)
84000500
SYNC Timing Synchronization failure - Loss of Sync
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
Critical (3)
84000500
  • 10.82K
  • 308
  • 631
Message 9 of 12
Hiya Ioan,
I appreciate you posting the router information.
The downstream power levels are still too high, the modem SNR is getting lower and with the network log it is showing the same time-stamp which you can reset when you get chance.
I think it is best that we arrange an engineer appointment to check this over for you. I've sent you a PM (purple envelope icon, right corner) requesting some details.
Speak soon
Sam
  • 6
IoanRsx
Message 10 of 12
Didn't want to post this on the forum because it wouldn't look good for VM, but I got a text yesterday from 07800 002204 saying that my Service Visit was cancelled because some VM engineers found some problem in my area and that they will confirm once it's resolved - 3 hours before they confirmed my appointment. Well, it's not fixed and now I guess I'll have to wait another couple of days until we get someone booked. Sorry to say, but I'm not amazed by the service, and if it were up to me, I would switch ISP's.
