  • 12
Thinkbecca
Message 1 of 18
Intermittent broadband for months
Hello,
For months now, our broadband access has been intermittent - the connection keeps dropping all the time, making it impossible to work from home.
The answer I got from support is that it's due to the upgrade and that works are being done in the area, but it's now been months, with no improvement. In the meantime the monthly cost has been increased... for a service that is hard to use.
Any advice?
Helpful Answers
  • 3.01K
  • 383
  • 952
Message 2 of 18
Re: Intermittent broadband for months
Can't comment on the alleged upgrade work, need VM staff to confirm that, but it doesn't sound quite right and it wouldn't be the first time call centre staff gave out inaccurate info.
Are you using a wired Ethernet connection to the VM hub or a wireless connection? Wireless is easily disrupted by a number of external factors, so knowing if a wired device drops out helps to pinpoint if the issue is with the wireless or your line.
As you are having issues working from home, can you confirm that the connection can drop at any time of day and not just at peak times in the evening and at weekends?
If wired connections are dropping at off peak times then some hub stats might help diagnose the issue.  Go to http://192.168.0.1/ (or http://192.168.100.1/ if you are in modem mode) to get the VM hub GUI. Don't login but instead click on Router Status which is either a button in the top right of the screen or a text link at the bottom of the screen depending on which hub you have. Click on the Downstream, Upstream and Network Log sections and copy & paste the figures from those screens and post them here, don't worry about the formatting or you can post screenshots if that is easier. Be careful to edit out or obscure any reference to your WAN IP or MAC address in the log to protect your privacy.
The community can have a look for you and see if anything in the figures looks wrong and advise accordingly. Or you can wait for the VM staff to pick up this thread (can take 7-10 days) and run checks on your line.
______________________
Scott
All Replies
  • 3.01K
  • 383
  • 952
Message 2 of 18
Scott
  • 3.88K
  • 121
  • 203
Forum Team (Retired) Adam_L
Message 3 of 18
Hi Thinkbecca,
Thanks for letting us know that your broadband has been intermittent for months, I apologise for any inconvenience caused.
I have tried to test your connection from here but I was unable to locate any of your details via your forum account. In order to proceed I will require some additional information from you.
I will send you a PM (purple envelope at the top) detailing what's required to proceed with diagnostics. Please respond to me there and I'll get this all sorted for you.
Take care,
Adam.
  • 12
Thinkbecca
Message 4 of 18
Hi Scott,
Thanks for your response!
To answer your questions:
  • The issue happens both on WiFi and wired connections
  • It happens at any time, day, evening, weekend
  • I have not been able to access the Hub GUI (even though I've been able to in the past!) on any device, not sure why?
Thinkbecca
  • 3.01K
  • 383
  • 952
Message 5 of 18
Hi Thinkbecca
Thanks for the reply, but probably best that you respond to Adam's PM as he is VM staff and can help you better than I could.
Scott
  • 3.88K
  • 121
  • 203
Message 6 of 18
Hi Thinkbecca,
Thanks for responding!
I have managed to test your connection and everything looks great! No errors or time outs inside the Hubs logs and all of the power levels are within the preferred ranges.
When the connection drops, what does the Hubs light sequence indicate?
Could you please include a recent copy of your Hubs logs in your response for me to compare with the data we have here.
Do all devices disconnect at the same time or is it just a select few that go off?
Speak soon,
Adam.
  • 12
Thinkbecca
Message 7 of 18
Hello,
When the connection drops, the Hub doesn't seem to have any particular light sequence, it's still in blue.
All devices are affected at the same time, whether they're connected in WiFi or cable.
How can I access the logs?
Regards,
Rebecca
  • 12
Thinkbecca
Message 8 of 18
Hello,
My connection is still very unreliable, and I still haven't been able to access the router logs.
Any suggestions?
Thanks for your help,
Rebecca
  • 3.01K
  • 383
  • 952
Message 9 of 18
@ModTeam I notice that Adam is not showing as being online since Friday, has this thread been forgotten about or assigned to somebody else in his absence?
Scott
  • 10.82K
  • 308
  • 632
Message 10 of 18
Hi there Thinkbecca,
Sorry for the late reply. Thanks Scott for bringing this to our attention.
I've managed to locate your account and there is an SNR (signal to noise ratio) fault in your area which is causing intermittent connection. The reference number is F005019571 and has a review date of 30th January.
I will check this on Monday for further updates and let you know.
Speak soon
Sam
