mtempley1
Message 1 of 5
Intermittent broadband and T3 timeouts
Hi there,
Starting on 27th Dec 16 we've been having some problems with our broadband. It doesn't actually disconnect but the internet will just hang for 30 seconds+ at a time. When it resumes, it goes back to the around 70mbps that I pay for. I've tried restarting all equipment to no avail. I've noticed as well that the up/down arrow has been constantly flashing during this period - at least 4-5 times a second.
I've checked the router network log and I'm seeing lots of T3 errors, as below:
30/12/2016 07:20:50 GMT 30/12/2016 07:20:50 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
Not sure if this is connected, but worth knowing as this is not normal.
Does anyone have any suggestions as to what I can do here?
Thanks in advance
[MOD EDIT: Subject heading changed to assist community]
  • 8.32K
  • 356
  • 585
Message 2 of 5
Re: Intermittent broadband & T3 timeouts
Hi mtempley1,
Welcome to the Community!
Sorry to hear you're having trouble with your connection.
I've run a diagnostic on your equipment and everything is looking great at the moment. No errors, levels as they should be and no network faults. Are you still experiencing the same problems? Let me know and we can look further into it for you.
Speak soon Smiley Very Happy
Josh
mtempley1
Message 3 of 5
Hi Josh,
Thanks for your reply. The problems seem to have cleared up now. Maybe they were due to christmas/ new years traffic?
If this happens again, do you have any tips for me to try?
Many thanks
  • 8.32K
  • 356
  • 585
Message 4 of 5
Hi mtempley1,
Thanks for getting back to me!
I'm glad to hear that's cleared up. If it happens again, drop me a message on here. I'll run a diagnostic on the equipment and try and pin down the issue. Hopefully you won't get any more trouble though!
All the best! Smiley Very Happy
Josh
mtempley1
Message 5 of 5
Hi Josh,
This issue appears to have resurfaced over the past few days. I've copied upstream and downstream pages from router status below. That total of 51 T3 timeouts was within approx 30-40 mins and internet was virtually unusable during this period. Although power levels are at around 48dBmV at time of snapshot, I did see it go to as high as 52.75dBmV (not sure if that makes a difference). Any help you can provide would be much appreciated.
Frequency (Hz)139000000147000000155000000163000000171000000179000000187000000195000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID12345678
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)4.934.874.394.224.664.453.773.49
RxMER (dB)37.3638.6138.2638.2638.9838.9838.2638.61
Pre RS Errors106185851113534383676374953344780346943372693335929
Post RS Errors5102007350310176150164130147916153601166806140677
  US-1 US-2 US-3 US-4
Channel TypeN/A2.02.0N/A
Channel IDN/A8381N/A
Frequency (Hz)N/A3260000046200000N/A
Ranging StatusOtherSuccessSuccessOther
ModulationN/A64QAM64QAMN/A
Symbol Rate (Sym/sec)N/A51200005120000N/A
Mini-Slot SizeN/A22N/A
Power Level (dBmV)N/A48.0048.25N/A
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts025510
T4 Timeouts0000
  Req(1) Init Maint(3) Per Maint(4) Adv Short(9) Adv Long(10) Adv UGS(11)
Modulation Type16QAMQPSK16QAM64QAM64QAM16QAM
Differential EncodingOFFOFFOFFOFFOFFOFF
Preamble Length56640384104104104
Preamble Value Offset65200716716716
FEC Error Correction (T)05510165
FEC Codeword Information Bytes (K)1634348122386
Maximum Burst Size0003255255
Guard Time Size84848888
Last Codeword LengthFixedFixedFixedShortenedShortenedShortened
Scrambler On/OffONONONONONON
