  • 6
scoattauto
Message 1 of 9
Intermittent Wireless Connection
I have an ongoing issue with my SuperHub 2. Every two or three days the wireless component of my router seems to lock up and not allow connections. Ethernet connections seem fine. I have done a spectrum scan and although it is quite congested I am confident that the channel selected should function fine.
Upon reboot of the router all devices connect successfully for a few days when another reboot is required. Below is the network log.
Any ideas would be most appreciated.
31/01/201721:17:36 GMT68010302DHCP WAN IP - XXXXXXXXX
31/01/201721:00:23 GMT68000407TOD established
Time Not EstablishedTime Not Established84000510Downstream Locked Successfully
31/01/201706:44:30 GMT68010600DHCP Renew - lease parameters tftp file-******** modified
31/01/201706:44:30 GMT68010400DHCP REBIND WARNING - Field invalid in response
31/01/201706:43:48 GMT68010100DHCP RENEW sent - No response for IPv4
31/01/201706:43:08 GMT68010100DHCP RENEW sent - No response for IPv4
31/01/201706:41:48 GMT68010100DHCP RENEW sent - No response for IPv4
31/01/201706:39:08 GMT68010100DHCP RENEW sent - No response for IPv4
31/01/201706:33:49 GMT68010100DHCP RENEW sent - No response for IPv4
31/01/201706:23:10 GMT68010100DHCP RENEW sent - No response for IPv4
31/01/201706:01:52 GMT68010100DHCP RENEW sent - No response for IPv4
31/01/201705:19:16 GMT68010100DHCP RENEW sent - No response for IPv4
31/01/201703:54:04 GMT68010100DHCP RENEW sent - No response for IPv4
31/01/201701:03:40 GMT68010100DHCP RENEW sent - No response for IPv4
30/01/201719:22:53 GMT68010100DHCP RENEW sent - No response for IPv4
30/01/201708:01:18 GMT68010100
Helpful Answers
  • 10.99K
  • 238
  • 2.03K
Message 7 of 9
Re: Intermittent Wireless Connection
Forum Team response is likely to still take until next week in order to check your cable segment but the perceived "router stall/hang" with WiFi is also disconcerting. In the meantime (and you haven't already done it recently) then perform FR with external recessed pin reset, ensuring you have backed up any extensive customised changes in VM485.bin file(and made a manual note). That may save some time if there is no obvious cable segment/local SNR issue and they decide to dispatch a replace hub first instead of an engineer?
Regards Tony
"Life is a Binary Inspired Turing Computed Hologram"(don't PM or @Mention me - in case ignoring you offends)
All Replies
  • 10.99K
  • 238
  • 2.03K
Message 2 of 9
scoattauto wrote:
I have an ongoing issue with my SuperHub 2. .....
Is it actually a SH2(VMDG485) or perhaps a SH2AC(VMDG490)? - You can check "tally labels" on underside....
However, in any event it's useful to post the firmware version anyway (and rest of the Down/UpStream stats). RouterStatus(don't login) > Status > Software Version.
The obvious clue will be if if f/w is V2.01.11 ?
Regards Tony
  • 6
scoattauto
Message 3 of 9
Hi Tony Thanks for the quick reply.
It is indeed a VMDG485. More info below:
able ModemEuroDOCSIS 3.0 Compliant
Serial Number3BW443WU1E23C
Boot Code VersionPSPU-Boot 1.0.20.1356
Software VersionV1.01.31
Hardware Version3.11
CA KeyInstalled
Cable Modem Status Item Status Comments
Acquired Downstream Channel (Hz)234750000Locked
Ranged Upstream Channel (Hz)35800000Success
Provisioning StateOKOperational
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)234750000242750000250750000258750000266750000274750000282750000290750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID4142434461626364
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)-0.54-0.57-0.91-1.82-1.80-0.99-0.40-1.30
RxMER (dB)37.6437.9437.3637.3637.6437.9438.2638.26
Pre RS Errors6289523501014310912948998
Post RS Errors295308296971308911947
997
Upstream   US-1 US-2 US-3 US-4
Channel Type2.0N/AN/A2.0
Channel ID6N/AN/A5
Frequency (Hz)35800000N/AN/A45800000
Ranging StatusSuccessOtherOtherSuccess
Modulation64QAMN/AN/A64QAM
Symbol Rate (Sym/sec)5120000N/AN/A5120000
Mini-Slot Size4N/AN/A4
Power Level (dBmV)47.00N/AN/A47.00
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts1000
T4 Timeouts0000
Upstream Burst   Req
(1) Init Maint
(3) Per Maint
(4) Adv Short
(9) Adv Long
(10) Adv UGS
(11)
Modulation Type16QAM16QAM16QAM64QAM64QAM64QAM
Differential EncodingOFFOFFOFFOFFOFFOFF
Preamble Length36384384646464
Preamble Value Offset39666396396396
FEC Error Correction (T)0556109
FEC Codeword Information Bytes (K)16343476231236
Maximum Burst Size0003018
Guard Time Size224848222222
Last Codeword LengthFixedFixedFixedShortenedShortenedShortened
Scrambler On/OffONONONONONON
General Configuration
Network AccessAllowed
Maximum Number of CPEs1
Baseline PrivacyEnabled
DOCSIS ModeEuroDOCSIS 3.0
Config File
SFID534
Max Traffic Rate80500000 bps
Max Traffic Burst10000 bytes
Min Traffic Rate0 bps
Primary Upstream Service Flow
SFID533
Max Traffic Rate5250000 bps
Max Traffic Burst8160 bytes
Max Concatenated Burst8160 bytes
Scheduling TypeBest Effort
First TimeLast TimePriorityError NumberDescription
31/01/2017 22:31:18 GMT31/01/2017 22:31:18 GMTCritical (3)82000200No Ranging Response received - T3 time-out
31/01/2017 22:19:16 GMT31/01/2017 22:19:16 GMTWarning (5)66050310Auth Success - Web login successful.
31/01/2017 22:19:08 GMT31/01/2017 22:19:08 GMTWarning (5)90000200CSFR Detect - Expired Content Submitted ; LAN Interface
31/01/2017 22:09:07 GMT31/01/2017 22:09:07 GMTWarning (5)66050310Auth Success - Web login successful.
31/01/2017 21:17:36 GMT31/01/2017 21:17:36 GMTError (4)68010302DHCP WAN IP - XXXXXXXXXXX
31/01/2017 21:00:23 GMT31/01/2017 21:00:23 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedNotice (6)84000510Downstream Locked Successfully
31/01/2017 06:44:30 GMT31/01/2017 06:44:30 GMTNotice (6)68010600DHCP Renew - lease parameters tftp file-******** modified
31/01/2017 06:44:30 GMT31/01/2017 06:44:30 GMTError (4)68010400DHCP REBIND WARNING - Field invalid in response
31/01/2017 06:43:48 GMT31/01/2017 06:43:48 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
31/01/2017 06:43:08 GMT31/01/2017 06:43:08 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
31/01/2017 06:41:48 GMT31/01/2017 06:41:48 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
31/01/2017 06:39:08 GMT31/01/2017 06:39:08 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
31/01/2017 06:33:49 GMT31/01/2017 06:33:49 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
31/01/2017 06:23:10 GMT31/01/2017 06:23:10 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
31/01/2017 06:01:52 GMT31/01/2017 06:01:52 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
31/01/2017 05:19:16 GMT31/01/2017 05:19:16 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
31/01/2017 03:54:04 GMT31/01/2017 03:54:04 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
31/01/2017 01:03:40 GMT31/01/2017 01:03:40 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
30/01/2017 19:22:53 GMT30/01/2017 19:22:53 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
  • 10.99K
  • 238
  • 2.03K
Message 4 of 9
Nothing obvious in signal levels and presumably the "Downstream" lock was you rebooting because WiFi was not responding? My SH2 is still on V1.01.29 and not used since July so I need to reconnect and see if I can replicate any of these symptoms but obvious questions are:
Do both 2.4 and 5G bands "lock up" (and Guest)?
Will dis/re-enabling WiFi/Radio restore WiFi connectivity.?
Does this affect any devices that have DHCP Reservation?
Can you still access Admin GUI (from cabled device) when WiFi hangs?
Regards Tony
  • 6
scoattauto
Message 5 of 9
Hi Tony,
This does seem to effect both 2.4 and 5GHz (not using guest access). Initially I suspected a DHCP problem so assigned reservations for a couple of devices. But these also are effected.
I have not tried turning off Wifi and back on again as the family are usually shouting at me to get it working. I will try when it happens again though.
Thanks for your help.
  • 6
scoattauto
Message 6 of 9
Just to update. I had a further outage today 2.4GHz light goes out on the router, 5GHz stays on but is not able to connect on either . This time the router web interface was not reachable from an ethernet port but I was able to ping the router and connect to devices on network after setting a static IP.
I then had to reboot the router twice to restore connection.
Network log below
02/02/2017 21:54:45 GMT02/02/2017 21:54:45 GMTError (4)68000407TOD established
02/02/2017 21:52:56 GMT02/02/2017 21:52:56 GMTWarning (5)66050310Auth Success - Web login successful.
02/02/2017 21:49:22 GMT02/02/2017 21:49:22 GMTError (4)68000407TOD established
02/02/2017 12:33:40 GMT02/02/2017 12:33:40 GMTCritical (3)82000200No Ranging Response received - T3 time-out
02/02/2017 12:33:39 GMT02/02/2017 12:33:39 GMTCritical (3)82000200No Ranging Response received - T3 time-out
02/02/2017 12:33:38 GMT02/02/2017 12:33:38 GMTCritical (3)82000200No Ranging Response received - T3 time-out
02/02/2017 12:33:37 GMT02/02/2017 12:33:37 GMTCritical (3)82000200No Ranging Response received - T3 time-out
02/02/2017 12:33:36 GMT02/02/2017 12:33:36 GMTCritical (3)82000200No Ranging Response received - T3 time-out
02/02/2017 12:33:35 GMT02/02/2017 12:33:35 GMTCritical (3)82000200No Ranging Response received - T3 time-out
02/02/2017 12:33:34 GMT02/02/2017 12:33:34 GMTCritical (3)82000200No Ranging Response received - T3 time-out
02/02/2017 12:33:32 GMT02/02/2017 12:33:32 GMTWarning (5)84020200Lost MDD Timeout
02/02/2017 12:33:31 GMT02/02/2017 12:33:31 GMTWarning (5)84020200Lost MDD Timeout
02/02/2017 12:33:30 GMT02/02/2017 12:33:30 GMTWarning (5)84020200Lost MDD Timeout
  • 10.99K
  • 238
  • 2.03K
Message 7 of 9
Regards Tony
  • 6
scoattauto
Message 8 of 9
Thanks tony,
I did a factory reset about a week ago which did not seem to have any effect.
Am I better to wait for support on the forum or raise a case by phone support? Can't stand the call centre script process.
  • 4.34K
  • 91
  • 282
Moderator
Moderator
Message 9 of 9
Hi scoattauto
Thanks for posting and apologies for the late reply here.  I'm really sorry to hear of the issues you've been experiencing with the wireless connection. Great to see the help you've had from horseman. I can see that the hub has been replaced when you called in so fingers crossed the replacement takes care of the problem. If you do experience any further issues with the new hub though please let us know and we can look into it for you.
Kind regards,
Ty
