  • 169
  • 7
jock1e
Dialled in
Message 1 of 22
I need my Super Hub 1 VMDG480 replaced or repaired.
Problems running security programs. and have so far reset my laptop back to factory settings 4 times. And only bought the laptop on January the first. Eset finds potential vulnerabilities in Router Vulnerability name EDB-31617A, bad access rights. Update the Firmware I was told but cannot find any update.
Helpful Answers
  • 16.49K
  • 1.37K
  • 3.36K
Message 2 of 22
Re: I need my Super Hub 1 VMDG480 replaced or repaired.
hiya @jock1e what security programs are you trying to run, as for the Eset possible showing a false positive, since with the hubs they'll have the latest update.
All Replies
  • 16.49K
  • 1.37K
  • 3.36K
Message 2 of 22
  • 169
  • 7
jock1e
Dialled in
Message 3 of 22
Eset Internet Security and Emsisoft.. I have never had any problems running them before and after 4 resets back to factory settings still getting the problems
Emsisoft forums and Eset forums have tried their best to help but cannot find the problem.
Contact your ISP I have been told by both of them.
I did get 3 critical errors on the router log last week but removed them just to see if they would come back.
  • 16.49K
  • 1.37K
  • 3.36K
Message 4 of 22
having critical errors on the hub log could just be standard CMTS errors with notihng to worry about, only getting issue if the log quickly fills up.
  • 169
  • 7
jock1e
Dialled in
Message 5 of 22
Both forums said the problem may have been the wrong time or date. One of the critical problems last week was Error ID 2436694078 TOD Established . Having Googled it TOD means time of day. Not sure if a router uses time and date so maybe a coincidence. It may also be a coincidence that my computer will not work properly after 4 factory resets.I can only conclude if it is not the new laptop that is the problem it must be the router.
  • 169
  • 7
jock1e
Dialled in
Message 6 of 22
Seen this on another post and though how helpful. (I've run a diagnostic on your account and I can see an issue with your modem SNR and a few timeouts. I'd like to send a technician to sort this out for you.) I have been on here since the beginning of January hoping that someone would do the same for me. No luck so far. It cannot take long to do a diagnostic test so anyone put me out of my misery and let me know if I have a faulty Router or not.
  • 16.49K
  • 1.37K
  • 3.36K
Message 7 of 22
yeah the TOD nothing to worry about its just checking the firmware matches up, you might get an few T3/T4 issues, DHCP errors etc.. nothing to worry about either..i'm still rather puzzled with the issue your having apart from getting a security warning, if this the only issue i wouldn't worry.
  • 169
  • 7
jock1e
Dialled in
Message 8 of 22
I have been trying to fix this new laptop for a month now and it all points to a router problem. I really need someone to check my router out. it only takes 5 minutes to check out the router like I said it has taken me a month so far trying to get the problem solved. like you say it maybe a false positive from Eset or it may not. Only one way to find out and I cant do it. Security programs cannot connect to the update center so although I put the proper keycode in they eventually revert back to the free versions again. I could really do with some help on here to find out if this is where the problem is coming from.
  • 169
  • 7
jock1e
Dialled in
Message 9 of 22
Ok as I was not getting any help from here I decided to reset the laptop back to factory settings this is either the 4th or 5th time. Had to as laptop was becoming unresponsive and I was having a hard time trying to get signed into it. So basically I have to know if this router has been hacked like Eset says. Will someone have a look see. If not able to do that at least tell me what I should be doing next. Should I be on here or should I be phoning Virgin for help. That is all I want to know.
  • 9.66K
  • 672
  • 1.87K
Message 10 of 22
phoning VM for help is a pointless exercise - you will get offshore and non of what you have posted is on their scripts so you will get no help - as to what you have posted - with respect it makes little sense - you pick up a comment in another thread about SNR errors - you refer to TOD errors - they are not your problem - not that i know what the problem is apart from being 99.9999999999999% certain its not the SH - its not been hacked and i would say its not faulty
it may be that the levels are out of spec
log into superhub - 192.168.0.1 - DON'T SIGN IN, click router status [top right] - and post the downstream and upstream figures
see what they say - you talk about a new laptop - what were you using before that to connect to the internet - did that work or do the problems go back before the new laptop
____________________
Tony
