gilescory
Hub keeps restarting
My hub keeps resetting frequently, here are the logs and config
 Any ideas?
Network LogDate And Time Error Number Event Description
2018-02-08 12:16:58.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:17:24.0068000500TFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:17:24.0068001101TFTP Request Retries exceeded, CM unable to register
2018-02-08 12:17:57.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:18:07.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:18:50.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:19:39.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:19:41.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:21:48.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:21:49.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:21:57.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:21:58.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:22:10.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:22:13.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:22:15.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:22:17.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:22:29.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:22:30.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:23:03.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-08 12:23:04.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Operational Configuration
General Configuration
Value
Network access
Enabled
Maximum Number of CPEs
1
Baseline Privacy
Enabled
Docsis Mode
Docsis30
Config file
Vee7a9a364ea87600.cm
SFID
414789
Max Traffic Rate
172500000
Primary Upstream Service Flow
SFID
414788
Max Traffic Rate
10500000
Channel ID
Frequency(Hz)
Mode
Power
(dBmV)
Modulation
Channel Bandwidth(Hz)
Symbol Rate (ksps)
12
25800000
ATDMA
47.5
64 qam
6400000
5120
10
39400000
ATDMA
47.5
64 qam
6400000
5120
Channel
Frequency(Hz)
Power
(dBmV)
SNR
(dB)
Modulation
Channel ID
1
179000000
-0.9
38.9
256 qam
6
2
323000000
-1.2
38.9
256 qam
24
3
315000000
-1.4
38.9
256 qam
23
4
307000000
-1.7
38.6
256 qam
22
5
299000000
-2
38.9
256 qam
21
6
291000000
-2.7
38.6
256 qam
20
7
283000000
-2.2
38.9
256 qam
19
8
275000000
-2.2
38.9
256 qam
18
9
267000000
-2
38.6
256 qam
17
10
259000000
-2
38.6
256 qam
16
11
251000000
-1.9
38.6
256 qam
15
12
243000000
-2
38.9
256 qam
14
13
235000000
-2
38.9
256 qam
13
14
227000000
-2
36.3
256 qam
12
15
219000000
-2.2
37.3
256 qam
11
16
211000000
-2
38.9
256 qam
10
17
203000000
-1.5
38.9
256 qam
9
18
195000000
-0.9
38.6
256 qam
8
19
187000000
-0.2
38.6
256 qam
7
20
171000000
-0.2
38.9
256 qam
5
21
163000000
0
38.6
256 qam
4
22
155000000
0
38.6
256 qam
3
23
147000000
0
38.9
256 qam
2
24
139000000
0.5
38.6
256 qam
1
Cable Modem Status
Item
Status
Comments
Acquired Downstream Channel(Hz)
179000000
Locked
Ranged Upstream Channel(Hz)
25800000
Locked
Provisioning State
Online
  • 6.86K
  • 182
  • 453
Re: Hub keeps restarting
Sorry to hear this gilescory,
I've located your details and I'm unable to detect any cause for this at the moment.
What connection are you having trouble with? Hardwired/wireless?
Hope to hear back from you soon,
Nat_J
