safeasmilk90
Hub Power Adaptor Replacement
The power cable for our Hub 3.0 has stopped working, does anyone know the best place to get a replacement?
Thanks in advance
  • 3.01K
  • 383
  • 952
Re: Hub Power Adaptor Replacement
Call VM on 150 from a VM phone or 0345 454 1111 and report the fault, they are responsible for replacing any faulty kit.  They should post a replacement out to you.
______________________
Scott
