  • 18
kinglaxy
Hub 3
Does anyone know if I can upgrade to Hub 3? And if it would cost?
  • 546
  • 42
  • 84
DavidJWalker
Rising star
Re: Hub 3
upgradeing maybe to 200mb gamer will get you hub 3 and only pay for P&P and it depends on the area if the area does not have 200mb its no point and stay with 2ac
Using VIVID 350 Optical Fibre, Player TV, Talk Weekends
Just another VM user trying to help out so my answers may be wrong.
If you do like my answer please mark it as helpful; it may help others
  • 18
kinglaxy
Re: Hub 3
thanks. I just realised I already have the hub 3! its because I have the white one and the new v6 box is advertised along side a really smart black one! I contacted virgin yesterday on chat but nobody understood that I wanted a black hub 3 instead of the white hub 3. no big deal but would look better !
  • 8.61K
  • 392
  • 1.38K
Re: Hub 3
Hi kinglaxy
Thanks for dropping by about the Hub 3.
We don't currently have the option to change the equipment for cosmetic purposes Smiley Sad
If the current Hub 3 you have is faulty at any point then we would swap this for you for an alternative Hub 3 and if the tech doing the swap has a black Hub 3 with him then you would possibly be able to change this at that point then. Obviously this would only be possible if there was an issue with the equipment and we were to either send a replacement if our diagnostics suggest this when you contact us or arrange an engineer booking and the engineer decides this is the best option for you.
My apologies that right now we can't just swap them over for you.
Kind regards.
